youtube videos not getting in serviio
venkat1926
Post Thu Oct 24, 2013 8:03 am
in the computer in the folder "serviio.plugin" folder following files are there.
youtube-embed-plus
in serviio console -library-onlinesurces two urls
http://gdata.youtube.com/feeds/api/vide ... mQ1wtWTgXU\
http://gdata.youtube.com/feeds/api/vide ... bqFY7UX0eU
still in Tv I could not get these videos.
but some videos are in computer folders. those are coming.
any suggestions.
Xmantium
Post Fri Oct 25, 2013 12:13 am
Re: youtube videos not getting in serviio
Not sure if you understand, ill explain in plain English
1. Download the YouTube groovy from here - download/file.php?id=2589
2. Move this Youtube.groovy to you plugin folder ( In windows its located C:\Program Files\Serviio\plugin )
3. Then in your Serviio console, add your YouTube RSS feeds
venkat1926
Post Fri Oct 25, 2013 5:25 am
SORRY. I APOLOGISE FOR IRRITATING YOU. I AM NEWBIE TO SERVIIO THOUGH VERY FAMILIAR WITH COMPUTER.
1. I have placed the file
youtube.groovy
in the folder.
c:\programfiles\serviio\plugin
I see this in the folder.
2. in serviio console -library-onlinesources I have added
3.saved the console
4.restarted the computer
5. I switched on TV changed source to
servioo
the above video is NOT there
in console-library-sharefolders
I have the entry
c:\users\public\videos\sample videos
now when I open TV
I get this sample videos . no problem
now I have a doubt. My tv is
SAMSUNG LA46D550
this is not a smart TV but an LCD TV.
is the problem because this TV is not a SMART TV.
Post Fri Oct 25, 2013 4:27 pm
What is in your serviio.log?
venkat1926
Post Sat Oct 26, 2013 2:14 am
thank for your patience. I greatly appreciate.
I am attaching from c:\program files\serviio\log
servioo.;log.docx
(211.8 KiB) Downloaded 426 times
Post Sat Oct 26, 2013 11:47 pm
Zip serviio.log up and attach it here
venkat1926
Post Sun Oct 27, 2013 4:37 am
thanks. I dont kow whether I have zipped correctly.though I am familiar with nnzipping files this is the first time I am zipping a flder or file
the method I used is thiis
I went to the folder
I rightlcicked the folder
and cllicked
add to log.rar
I saw the zipped item(zip icon) in the folder c:\lprogram files\serviio
and I attached here.
log.rar
(5.79 KiB) Downloaded 373 times
Post Sun Oct 27, 2013 11:11 am
yes, that was right. The log has not the info I need, so you'll have to enable detailed logging and the send the log again
venkat1926
Post Sun Oct 27, 2013 1:22 pm
thanks. I shall try your suggetions. I presume that I have to right click the xml file and click edit and make the changes
hope this will work. If this works I shall cofirm.
if not can I have your permission and indugence to refer back to you
Xmantium
Post Sun Oct 27, 2013 10:50 pm
venkat1926 wrote:5. I switched on TV changed source to
servioo
I have the entry
now when I open TV
Are you sure your checking the correct folder?
Your YouTube videos should be in the folder called "Online" on your Samsung TV
venkat1926
Post Mon Oct 28, 2013 2:17 am
Xmantium
thanks for response.
I have placed those you tube videos only under "onlline resoruces - "onlilne rss/atom feed
what I meant was that the items placed under shared folders come but items under"online resources" do not come.
thanks once again.
Xmantium
Post Mon Oct 28, 2013 10:49 am
I meant on your TV, what do see inside the folder called "Online"
venkat1926
Post Mon Oct 28, 2013 12:50 pm
perhaps I have not understood
in the savioo console -library-online resource-
under online Rss/atomfeed these four files are put.
videos
http://gdata.youtube.com/feeds/api/vide ... d_GmVmTKjg
http://www.archiveclassicmovies.com/index.php
http://liveips.nasa.gov.edgesuite.net/msfc/Wifi.m3u8
and an audio file
http://www.4shared.com/mp3/U7NvklzT/file.html
now I go to TV (LA46D550) and change source to
ALL SHARE SAVIIO
Under video I get only what I have put under sharef folder that is a file in the computer folder
c:\users\public\sample videos.
This is seen in the TV and acutall viewed the video.
NONE of the videos I have under online source in saviio console does show under video(there are three folders IN tv whenI change the source, namely video,audio,images.
I hope I have given the input which you have in mind.
Post Mon Oct 28, 2013 4:15 pm
On the TV go to Videos -> Online Sources (if you don't see the folder Online Sources, make sure it's enabled in the console on Presentation tab).
Also, the NASA stream is not a RSS feed, it's a live feed. Try to click on this ServiioLink to add that to your library:
serviio://video:live?url=http%3A%2F%2Fl ... ame=Nasa+2
venkat1926
Post Tue Oct 29, 2013 4:28 am
ZIP
THANKS A LOT
in console-presentation-
under video
i have made "online"
display category
others under video disable
saved
(by the by three choices are there "display category","display contents only" and "diable")
under consolde-library-online source-onlineRSS/atom feed
I have given name "FRENCH FILM"
go to tv
source
allshae-serviio
(three items video,audio,images)
clicked video
three subfolders
title,FRENCH FILM ,KIDS(short name for another video under onlilne resoursces)
click titles
folder for shared folder from the computer came up and I am able to run it
when i shifed to FRENCH FILM" OR "kids" it shifts to
"upper foldr" and nothing happens.
I do not know where I do wrong?
can you please give me one url for online resource under "online RSS/atom feeds) which you have successflly run(preferably youtube video) I can try it. My doubt is that the url for French film is not correct for serviio.
what type of urls go under online Rss/atom fee/live streams/web resource
thank you once again.
I have downloaded many software and installed. this gives me problem.
Post Wed Oct 30, 2013 9:48 pm
venkat1926
Post Thu Oct 31, 2013 3:26 am
thank you.
when I copy the url iin llibrary onlline resoource
and when I save error message comes
provided url not valid.
I GIVE UP .
thanks for all the help you have given with patience.
venkat1926
Post Thu Oct 31, 2013 3:28 am
after all I am getting shared folders from the omputer in SAVIIO.. I shall save the videos in my computer and then sese in tv. I also connected TV to my PC by HDMI cable and can use TV either as a clone monitor or independent monitor.l
venkat1926
Post Thu Oct 31, 2013 6:59 am
I was too hasty. sorry. in spite of error message while saving console I found that url is avilable it is there in tv. Now could get the youtueb video. it looks the item youo have sent
serviio://video:feed?url=http%3A%2F%2Fg ... Ftop_rated
seems to work. I shall try some more times with some more ;outube videos and give feeback to yuou
Though I have not understood the sequences I shall get back to you
I gsreatly appreciate your waondreful helpl
venkat1926
Post Thu Oct 31, 2013 7:25 am
I have entered your llink
in the library-onliesources and added this
however as it gave an error message I removed it. stilll it seems to work. how?
kindly tell me where and which folder I sholod park the above link
Users browsing this forum: No registered users and 94 guests
