A couple of unsupported files in library
mysteray
Post Wed Dec 04, 2013 1:36 pm
First of all, I am quite impressed of how well this server works.
I am running the server on synogy NAS DS-114.
There are just a couple of files that keep getting logged, as they can't be added to the library. For the videos, I post the results of ffmpeg -i further down.
For one picture I get this in the detailed log:
serviio.log.4:2013-12-04 13:14:32,192 DEBUG [MediaItemDAOImpl] Media item /volume1/public/pictures/2009 - Australia/David and Kim 2.jpg doesn't exist in DB yet
serviio.log.4:2013-12-04 13:14:32,193 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
serviio.log.4:2013-12-04 13:14:32,193 DEBUG [ImageMetadataRetriever] Unknown image format, trying raw format
serviio.log.4:2013-12-04 13:14:32,193 DEBUG [DCRawWrapper] Invoking DCRAW to retrieve thumbnail from file: /volume1/public/pictures/2009 - Australia/David and Kim 2.jpg
serviio.log.4:2013-12-04 13:14:32,194 DEBUG [ProcessExecutor] Starting dcraw -c -e /volume1/public/pictures/2009 - Australia/David and Kim 2.jpg
serviio.log.4:2013-12-04 13:14:32,264 WARN  [LibraryManager] Skipping processing metadata for an unsupported file (David and Kim 2.jpg). Message: Cannot read raw image file /volume1/public/pictures/2009 - Australia/David and Kim 2.jpg using dcraw
What other info is needed here for you to find out, what's wrong with it?
On a couple of vidoefiles I get this as a result:
/volume1/@appstore/Serviio/bin/ffmpeg -i "/volume1/public/videos/Le
arning Videos/Music/TrueFire - Jump Start/TrueFire - Jump Start - Rock Guitar -
DATA-DVD (2011)/data/jam/jsjsrg17.flv"
ffmpeg version 2.1-compiled_by_patters_for_Serviio Copyright (c) 2000-2013 the FFmpeg developers
  built on Nov  6 2013 18:18:56 with gcc 4.6.4 (Linaro GCC branch-4.6.4. Marvell GCC 201303-1655.6f19debc) 20120731 (prerelease)
  configuration: --arch=arm --enable-cross-compile --cross-prefix=/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi- --target-os=linux --prefix=/usr/local/arm-marvell-linux-gnueabi --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-neon --enable-thumb --disable-debug --enable-pthreads --enable-libmp3lame --enable-librtmp --enable-libass --enable-libx264 --enable-gpl --pkg-config=pkg-config --extra-version=compiled_by_patters_for_Serviio
  libavutil      52. 48.100 / 52. 48.100
  libavcodec     55. 39.100 / 55. 39.100
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
Input #0, flv, from '/volume1/public/videos/Learning Videos/Music/TrueFire - Jump Start/TrueFire - Jump Start - Rock Guitar - DATA-DVD (2011)/data/jam/jsjsrg17.flv':
    encoder         : Lavf52.104.0
  Duration: 00:00:57.18, start: 0.000000, bitrate: 132 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
Then I've got a couple of ripped DVDs from which some vob files put out this when ffmpeg -i is used on them:
/volume1/public/videos/Learning Videos/Music/Hal Leonard - Guitar Play-Along/Hal Leonard - Guitar Play-Along - DVD - 13 - The Doors/VIDEO_TS/VTS_09_0.VOB: Invalid data found when processing input
Others in the same subfolder would be fine but seem to get skipped checking. Why is that? For instance, there is another file in the same folder, which when checked with ffmpeg puts out:
DiskStation> /volume1/@appstore/Serviio/bin/ffmpeg -i "/volume1/public/videos/Le
ong - DVD - 13 - The Doors/VIDEO_TS/VTS_09_1.VOB"
Input #0, mpeg, from '/volume1/public/videos/Learning Videos/Music/Hal Leonard - Guitar Play-Along/Hal Leonard - Guitar Play-Along - DVD - 13 - The Doors/VIDEO_TS/VTS_09_1.VOB':
  Duration: 00:02:08.29, start: 0.300300, bitrate: 11177 kb/s
    Stream #0:0[0x1bf]: Data: dvd_nav_packet
    Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, fcc), 720x480 [SAR 32:27 DAR 16:9], max. 4797 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
    Stream #0:2[0x80]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
    Stream #0:3[0x81]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s
However, this file will never get added to the library.
One final question. If there are files, which just can't get recognized, should they be removed from the shared folder?
Your help is greatly appreciated. Big thanks.
Post Thu Dec 05, 2013 5:01 am
Re: A couple of unsupported files in library
For the videos, I might be mistaken but I don't believe VOB is a supported format. I rip all my DVDs into MKV containers and they work perfectly. Depending on the playback device multiple audio tracks and captions are available.
Post Thu Dec 05, 2013 8:53 pm
VOB is supported.
The FLV file doesn't have video track (according to FFmpeg), so it's not added as a video file.
The other VOB looks fine, are the access rights on the file correct? If you move it to another folder, is that added?
The image - not sure, looks like the library I'm using cannot detect what file type it is.
VOB is supported.
Users browsing this forum: No registered users and 63 guests
