Still Can't get metadata perfect
spoonfed
Post Thu Dec 12, 2013 10:17 pm
I've got a library of over a thousand movies which have mostly been correctly identified by themoviedb.org however I've got a stubborn selection that simply will not be tamed.
I'd hoped that I could create .NFO files for the unrecognised files but as serviio looks at the online source first it hasn't helped. I don't want to have to go back through the 1100 movies and create .NFO files for all of them.
Could serviio not simply change the meta source order, if an .NFO is available it is used, then it moves on to the online source for the rest? Surely that makes perfect and reasonable sense?
The films I cannot resolve are...
Harry Potter and the Deathly Hallows Part 1 (2010).nfo
Harry Potter and the Half-Blood Prince (2009).nfo
Hellboy (2004).nfo
Hellboy II The Golden Army (2008).nfo
Pirates of the Caribbean At World's End (2007).nfo
Scott Pilgrim vs. The World (2010).nfo
Spider-Man 3 (2007).nfo
St. Trinian's (2007).nfo
St. Trinian's II The Legend of Fritton's Gold (2009).nfo
The A-Team (2010).nfo
The Twilight Saga Eclipse (2010).nfo
The Twilight Saga New Moon (2009).nfo
Wall Street Money Never Sleeps (2010).nfo
X-Men Origins Wolverine (2009).nfo
Mr. & Mrs. Smith (2005).nfo
The Chronicles of Riddick Dark Fury (2004).nfo
Tremors 4 The Legend Begins (2004).nfo
Instead all I get is a list of 14 films called 12 and 3 called 15!!
These are exactly as listed on themoviedb.org but for whatever reason they are not correctly being resolved. If you copy/paste the titles into the website they're not found either, which really doesn't help my sanity!!
How can I get out of this hole I'm in?
I've got 1129 movies that are identified correctly and these 17 that won't play ball.
Could I just put the imdb identifier somewhere in the filename?
Post Thu Dec 12, 2013 11:20 pm
Re: Still Can't get metadata perfect
Cross checking a few I have - try renaming your files to (use whatever file extension it is currently):
  • Harry Potter and the Half Blood Prince.mkv - I don't have the year on this one, works fine, but if you're sure that the year is correct leave it in - I suspect its the "-" in your filename.
  • Twilight New Moon (2009).mp4
  • Twilight Eclipse (2010).mp4
  • X-Men Origins Wolverine (2009).avi - same as you???
  • The Chronicles of Riddick Dark Fury (2004).mp4 - same as you???
Something to try: remove all the special characters [.-'] from the file names. Also:
  • do you use Filebot to help resolve names - if not, highly recommended (see my post here: viewtopic.php?f=5&t=10626&p=70544#p70544).
  • make sure the folder name also don't have special characters. Does "12" or "15" appear in the path anywhere?
  • do these movies show up under the Folders category?
  • last, if none of the above helps try posting a detailed log after pressing the library refresh.
When pasting into the themoviedb.com remove the year from the pasted filename - that should then find the movie.
There is an open ticket on this request: https://bitbucket.org/xnejp03/serviio/i ... for-movies
spoonfed
Post Fri Dec 13, 2013 1:45 am
Thanks for the quick response.
I'm away from that setup now so can't try your suggestions, although I suspect removing the special characters may help. On themoviedb.org when I include the year in brackets these files didn't provide a result at all.
More frustrating is the fact that I have the same list of files on a different server added at an earlier date and they have all been correctly identified.
Instead I have Flashdance (1983).mp4 that refuses to be identified. Flashdance.mp4, flash dance.mp4 & Flash Dance (1983).mp4 don't work either. Is serviio simply making a stand against 80s leotards?
How difficult would it be to allow the user to choose the order of preference for metadata sources.
I'll let you know how I get on with the list of 17. The files on that server have been categorised by BBFC age rating so that would explain the 14 named 12 and 3 named 15.
spoonfed
Post Tue Dec 17, 2013 4:47 pm
It seems I could not resolve the issues with any of the files I listed.
However, once I moved them into the 'root' directory of my Films folder, they were then correctly identified.
So it was my sorting of them by BBFC age rating that had contributed to the fault.
Any suggestions on how I could be able to group my movies by an age range (or other folder structure) so the kids can more easily find their appropriate selection?
Would I need a more descriptive folder name than 12, say '12 certificate movies' or something. Incidentally why does the metadata search seem to find the name of the folder more important than the name of the actual file? Isn't that a little backwards?
My folder structure..
Films
-->12
-->15
-->18
-->climbing
-->Foreign
-->French
-->German
-->Kids U & PG
-->TV
I have 181 films in 12
323 films in 15
119 films in 18
15 films in climbing
47 films in foreign
65 films in french
11 films in german
363 films in Kids U & PG
then these 16 movies that refused to be identified
I have a Samsung TV that has a 1000 item limit and will not provide a second page so I decided to sort the films as above so the TV could cope.
Post Tue Dec 17, 2013 11:18 pm
Version 1.4 of Serviio will include a feature to categorise movies by Rating (uses MPAA movie rating from the metadata) - this may resolve your issue.
Other than that, there is something in the folder name that Serviio doesn't like. You will probably need to play with the folder names to work it through (eg. try a more descriptive folder name as you suggest).
spoonfed
Post Wed Dec 18, 2013 2:07 am
Thanks, changing the folder names seems to have resolved it.
I now have..
Films
-->climbing
-->Foreign
-->French
-->German
-->Grown Up Films
-->Kids Films
-->Teenagers Films
-->TV
All is well.
Ooh, if you're going to implement age ratings in the next version, will we be able to set a watershed where anything above a certain rating would only be served after a set time. I.E. no R ratings between 4am and 9pm?
Post Wed Dec 18, 2013 2:16 am
Not in the next release. It's one for the developer (zip) but you may want to request the feature (there have been similar requests, but none time based afaik).
Users browsing this forum: No registered users and 60 guests
