Serviio 1.4.1.1 install issues
amerkfan
Post Fri Mar 21, 2014 5:26 pm
I am running ubuntu server 12.04, and serviio 1.4.1.1 headless.
After removing an earlier version and installing v1.4.1.1 I cannot connect via web interface and serviidroid gives me this error when I try to add a folder to the library " The server did not understand the request which is probably because something has been removed from the REST api. Please contact me to fix this." When I try to access via the web I get an error: "The server has been stopped" even though 'service serviio status' yields serviio start/running, process 18870
My serviio.log is attached
Thanks in advance
(3.33 KiB) Downloaded 704 times
Post Fri Mar 21, 2014 6:13 pm
Re: Serviio 1.4.1.1 install issues
something wrong with the database. Try to install again and make sure you have write access to the serviio folders
Return to General discussion
Users browsing this forum: Baidu [Spider] and 5 guests
