HDD Not Hibernating on Synology 213j
All installed 1.2.1 on the synology 213j, however the hdd's dont seem to ever spin down and enter hibernation.
library set to only refresh every 1440mins.
Any help would be appreciated.
Package Center installs the application to /volume1/@appstore/Serviio though from what I understand, on multi-volume systems the user is prompted for a destination volume. If you need to edit device profiles or enable debug logging then that’s where you’ll find the files. You will need to use an SSH session to access this folder – it’s not browsable in DSM’s File Station. The simplest way to edit these files if you’re not really confident with Linux is to install Merty’s Config File Editor package, which requires the official Synology Perl package to be installed too (since DSM 4.2). Load Config File Editor, then in the dropdown menu edit Config File Editor’s own config (it’s the last in the list) and add the lines:
/volume1/@appstore/Serviio/config/profiles.xml,Serviio-profiles
/volume1/@appstore/Serviio/config/log4j.xml,Serviio-logging
Make sure to add an extra blank line underneath, save, then relaunch CFE and you’ll have an entry for Serviio in the dropdown. You’ll need to restart the Serviio package for any changes to take effect.
Users browsing this forum: Baidu [Spider] and 18 guests
