HDD Not Hibernating on Synology 213j
mediaman23
Post Thu Aug 29, 2013 8:37 pm
Firstly a huge thank you to patters and all those who have spent so much time and effort freeing us from the grip of sony crippling their players from streaming mp4's etc.
All installed 1.2.1 on the synology 213j, however the hdd's dont seem to ever spin down and enter hibernation.
library set to only refresh every 1440mins.
Any help would be appreciated.
Post Thu Aug 29, 2013 9:07 pm
Re: HDD Not Hibernating on Synology 213j
mediaman23
Post Fri Aug 30, 2013 1:06 pm
Dear Will
Thank you for the info. As a newbie, I would be grateful if you could specify exactly which file I need to change, where i will find it, and what line i need to add / fix.
many thanks. much appreciated
mediaman23
Post Sun Oct 06, 2013 8:20 pm
I am using Serviio 1.2.1 on a Synology 213j, with Java6
Which file do i need to adjust to stop the system checking for plugin updates? I can't seem to find any of the serviio files on my server (I assume they are hidden), despite it working well.
thks
Post Sun Oct 06, 2013 8:26 pm
I don't have one, so am not sure, but from the notes section of the package you installed http://pcloadletter.co.uk/2012/01/25/se ... o-package/
Package Center installs the application to /volume1/@appstore/Serviio though from what I understand, on multi-volume systems the user is prompted for a destination volume. If you need to edit device profiles or enable debug logging then that’s where you’ll find the files. You will need to use an SSH session to access this folder – it’s not browsable in DSM’s File Station. The simplest way to edit these files if you’re not really confident with Linux is to install Merty’s Config File Editor package, which requires the official Synology Perl package to be installed too (since DSM 4.2). Load Config File Editor, then in the dropdown menu edit Config File Editor’s own config (it’s the last in the list) and add the lines:
/volume1/@appstore/Serviio/config/profiles.xml,Serviio-profiles
/volume1/@appstore/Serviio/config/log4j.xml,Serviio-logging
Make sure to add an extra blank line underneath, save, then relaunch CFE and you’ll have an entry for Serviio in the dropdown. You’ll need to restart the Serviio package for any changes to take effect.
So you will want to edit
/volume1/@appstore/Serviio/bin/serviio.sh
and add it to the JAVA_OPTS line near the bottom.
Either do it using SSH, or the method mentioned in the above quote.
skyver
Post Sun Nov 03, 2013 4:54 am
Login with the root account and edit the file "/volume1/@appstore/Serviio/bin/serviio.sh" using vi cmd and append " -Dplugins.check=false" at the end of the line JAVA_OPT
bengio
Post Fri Feb 21, 2014 8:28 pm
Hi. Also I have the same problem...
The HDD go to Hibernating but after 1 or 2 hours HDD wake up.
I have used config file editor on DSM (access like admin)
and i have modified Servii file like and write "-Dplugins.check=false" like these:
# Setup Serviio specific properties
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.defaultTranscodeFolder=/volume1/@tmp -Dffmpeg.location=$SERVIIO_HOME/bin/ffmpeg -Dplugins.location=/volume1/public/serviio -Dplugins.check=false -Djava.util.prefs.syncInterval=86400"
In ServiiDroid, in the advanced section I have unchecked
- Automatically updates
- Research updates
In DSM in the control panel I set for the suspension of the HDD 10 minutes.
Thks a lot.
ServiiGo beta tester
patters
Post Tue Mar 25, 2014 12:19 pm
This may also help - Version 1.4 Release Notes include:
. license checking thread now runs once a day not to wake NASes too often; ticket #739
bengio
Post Fri Apr 25, 2014 7:06 pm
Thanks. Now it works correctly
Inviato dal mio GT-P6200 utilizzando Tapatalk
NRB
Post Sun Jun 15, 2014 11:05 am
My DS413 still won't hibernate when serviio is running. When it's off, the NAS hibernates after 10 minutes as programmed to.
I've added "-Dplugins.check=false" as described.
NRB
Post Sat Jul 12, 2014 12:47 pm
Anyone?
NRB
Post Mon Aug 04, 2014 10:09 am
bump
snowflake7
Post Wed Aug 06, 2014 5:12 pm
Bump DS214Play
Bump DS412+
NRB
Post Wed Oct 22, 2014 11:26 pm
My NAS is still not hibernating. Is any work being performed to find a solution?
NRB
Post Sun Nov 23, 2014 12:38 am
I was wondering if anyone is actually working on this problem? Does anyone monitor this sub-forum??
spelac
Post Thu Dec 11, 2014 6:19 am
Same here. Not hibernating at all...
NRB
Post Fri Mar 27, 2015 10:55 am
Still the same problem
