Version 0.3 released
It's been a while but 0.3 is finally out. The biggest new feature is separation of the application into a server part and a UI console part - you'll have to run them separately.
You don't have to worry about it if you're on Windows, the server part will start automatically after Windows boots up (as a Windows service). The console will start after a user log in (you'll see Serviio icon in system tray area, as before). On Mac and Linux you'll have to start them separately (server first, then console if you need to use it). I presume you could accomplish starting the server automatically similarly to Windows using your OS's tools.
This separation will also enable connecting to the server from any UI. I'm looking for someone to write WHS add-in at the moment.
This release also includes a few critical fixes which should further enhance device compatibility.
If you're missing something, let me know in the forum.
Have fun,
Have fun,
Petr
Help translate Serviio
