.sub files not working on UE48H6200
LAtee
Post Mon May 09, 2016 4:27 pm
Hi!
I have weird problem with my UE48H6200.
Tried to play .avi file with subtitles which was .sub, both named correctly.
Video shows fine on TV but subtitles are showing only some of the texts.
I tried to change coding settings from TV, but no luck.
Later on I tested with .mp4 and .srt, worked fine so seems to be that the issue is either with .avi files or with .sub files.
Any clue? :oops:
EDIT: Although LG issues won't belong here, same problem with my other TV (= LG), model 47LM649T-ZB.
Post Tue May 17, 2016 4:36 pm
Re: .sub files not working on UE48H6200
Probably the file is encoded in non utf-8 encoding. Either change the file to be utf-8 or set the encoding in the console.
