Samsung LE37C650 can't see serviio
N3uRo
Post Sat Mar 19, 2011 11:18 am
I have a problem with serviio (you can see the log if you want).
I have configured all.
- Mi PC with serviio is 192.168.10.100
- Mi Samsung TV is 192.168.10.101
- In serviio "bound ip address" I have the PC ip 192.168.10.100
I have a WR941N (primary connected to the adsl) and a WRT54GL (secondary connected to the tv wired) linked each other with WDS wirelessly. I have no problems with that, I have my lan with shared folders and I can see all devices (I mean speaking about computers or consoles).
On serviio I can see the TV with the green dot on the left but on the TV when I go to "Allshare" option I see nothing there. It doesn't detect event the server.
Serviio log
(27.87 KiB) Downloaded 1444 times
N3uRo
Post Sat Mar 19, 2011 1:28 pm
Re: Samsung LE37C650 can't see serviio
Finally!! The problem was the Windows 7 firewall.
According to the serviio doc, it says that "If you are using Windows Firewall these will be open for you automatically by the installer."
In my case I've to do it on my own. Thank goodness I thought to disable the windows firewall and give a try.
I hope that this help to anyone with this problems.
Post Sat Mar 19, 2011 5:08 pm
N3uRo wrote:Finally!! The problem was the Windows 7 firewall.
yes the installer does BUT it asks if you want it to allow serviio access to teh network if you say NO the ports wont be opened ;)
N3uRo
Post Sat Mar 19, 2011 10:12 pm
So my Windows 7 is dumb because it hasn't ask me anything (I swear).
I know you refer to the message that ask you to allow a program in the firewall and it gives you apart from allow or deny, 3 options to choose about the lan location (private, public or work).
But the point in this post is to help other people that has a similar problem.
Thanks anyway!!! :D
