I can not play files larger than 2GB (or so)
jibtga
Post Fri Mar 18, 2011 10:20 am
I have a Samsung C6000 and when I play the file is over 2GB in size, the program closes. I also the case with PCShare Manager (Samsung program). I attached a file traces.
Thanks in advance
log file
(145.01 KiB) Downloaded 818 times
Post Fri Mar 18, 2011 3:09 pm
Re: I can not play files larger than 2GB (or so)
Does the program (Serviio) crash or the TV stops playing the file? If the latter, it's probably something about the file (seeing Samgung SW does the same). Otherwise there is no limitation of file size on Serviio's side.
jibtga
Post Mon Mar 21, 2011 1:07 pm
Don't start playback of the file and the program (Serbiio or Samsung PC Share manager) disappears from the menu on the TV as multimedia source. Yes, the same goes for the samsung software. Maybe someone has any idea ...
