Samsung UE55KS7002U disconnects from Serviio 1.8 macOS
miric
Post Fri Jun 23, 2017 6:06 am
Hi everybody.
I recently upgraded my old 40'' Samsung ES series which worked flawlessly with different versions of Serviio macOS for almost 4 years. Thanks Serviio developers.
Now I have Samsung UE55KS7002U and the issue that now when TV connects to Serviio (macOS, 1.8, WI-FI 5GHz, Mikrotik hAP ac router) via TV source list in Smart Hub, it disconnects after a couple of seconds. It's not all the time behavior but for example this morning the situation is completely bad. I tried to reconnect many times. Sometimes I even reach my Video folder but then disconnect again. I used Generic DLNA profile as well as Samsung J-series profile with that TV set. I rebooted TV and my Mac mini where Serviio works. I restarted Serviio server itself. No result. Debug log doesn't show anything particular. How could I fix that? Has anybody encountered such failure?
UPD1. Maybe I was wrong about log. I've attached log part while connect/disconnect.
7002-log.txt
(18.58 KiB) Downloaded 872 times
miric
Post Sat Jul 08, 2017 2:41 pm
Re: Samsung UE55KS7002U disconnects from Serviio 1.8 macOS
Any thoughts on this issue? Serviio still drops connection. I increased advertising time in config but it have not had any results :(
