How to play MOV and MTS files
killer
Post Tue Mar 15, 2011 2:49 am
Hi, my name is Flavio and I have a Samsung UN40B7000 (a "B" Series) and even with Serviio it doesn´t play MOV (Quicktime) and MTS (AVCHD) files (both of files generated from my Panasonic Lumix pocket camera). I tried to edit the "profiles.xml" but everytime that I do the program crashes. Below I post the ffmpeg -i
I hope you can help to play them, thanks
----------MTS FILE------------
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "J:\Movies\HD\0teste\00005.MTS"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 119.88 (12000
0/1001) -> 29.97 (30000/1001)
Input #0, mpegts, from 'J:\Movies\HD\0teste\00005.MTS':
Duration: 00:00:44.03, start: 0.369989, bitrate: 15133 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 29.9
7 fps, 29.97 tbr, 90k tbn, 119.88 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
----------MOV FILE------------
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "J:\Movies\HD\0teste\000P1020590.MO
V"
686-mingw32-
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'J:\Movies\HD\0teste\000P1020590.MOV':
major_brand : qt
minor_version : 537331972
compatible_brands: qt pana
creation_time : 2011-03-14 22:23:44
Duration: 00:00:16.50, start: 0.000000, bitrate: 17135 kb/s
Stream #0.0(eng): Video: mjpeg, yuvj420p, 1280x720, 16621 kb/s, 30 fps, 30 t
br, 30 tbn, 30 tbc
Stream #0.1(eng): Audio: pcm_s16be, 16000 Hz, 2 channels, s16, 512 kb/s
Post Tue Mar 15, 2011 12:47 pm
Re: How to play MOV and MTS files
The mts file, I'm not sure, it looks ok. Could you post mediaInfo result of the file?
The mov will need to be transcoded, try to replace the Samsung B profile with this:
<Profile id="2" name="Samsung TV (B-series)" extendsProfileId="1">
        <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
        <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
        <Detection>
            <UPnPSearch>
                <FriendlyName>^TV$</FriendlyName>
                <ModelName>Samsung DTV DMR</ModelName>
                <ModelNumber>1\.0</ModelNumber>
            </UPnPSearch>
        </Detection>
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
        </MediaFormatProfiles>
            <!-- transcode MKV with DST audio to AC3, remux into mpeg2ts -->
            <!-- transcode H264 MP4 files with LPCM audio -->
                <Matches container="matroska" vCodec="h264" aCodec="dca" />
                <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
            <!-- transcode unsupported codec/container combinations into mpeg2ts -->
            <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
                <Matches container="asf" vCodec="wmv2" />
                <Matches container="flv" />
            <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
            <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
                <Matches container="asf" vCodec="mpeg2video" />
                <Matches container="wtv" />
            <!-- transcode audio only for wmv with wmapro -->
            <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
                <Matches container="asf" aCodec="wmapro" />
                <Matches container="asf" />
                <Matches container="mp4" />
                <Matches container="flac" />
                <Matches container="ogg" />
            </Audio>
        <SubtitlesMimeType>smi/caption</SubtitlesMimeType>
killer
Post Wed Mar 16, 2011 2:55 am
Thanks for the reply!!! I applied the config that you suggested and it worked to transcode MOV files! But it wasn´t clear for me what kind of transcoding it was used. I could understand that the "mp4" container will be decoded with "mjpeg" codec and after encoded with "mpeg2video" codec, am I right?
About the MTS file, the file runs only the video, but no audio. My camera record it in AVCHD Lite mode for video and AC-3 stereo for Audio. It´s kind of weird because the TV reads MKV with AC-3 audio, maybe this one is a little bit different AC-3 and the TV doesn´t recognize it to play. I think that it need to be transcoded, but I don´t know if just a little change at the header is sufficient, or if it have to be transcoded to other audio format, just to make it more "compartible" with the tv. Here is the mediainfo about this file
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Frame mode : Frame doubling
Codec ID : 27
Duration : 44s 27ms
Bit rate mode : Variable
Bit rate : 14.3 Mbps
Maximum bit rate : 16.6 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.519
Stream size : 75.2 MiB (95%)
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 44s 64ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.01 MiB (1%)
Post Wed Mar 16, 2011 9:42 am
Yes, transcodes mjpeg into mpeg2video and the lpcm sound into ac3. Try adding aBitrate="256" (or 384) to the second Video config element, like this:
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="256">
killer
Post Thu Mar 17, 2011 1:19 pm
Well, the MOV file is been transcoded and I can whatch it at TV, it´s ok, but about the MTS file, the audio (AC-3) is still missing when playing. I think that there is no way to solve it because Serviio knows that AC-3 is already supported by the TV so it just doesn´t do transconding, and if it does, I think that it will transcode every AC-3, even those that are in my MKV files that, today, plays flawsless without transcoding. I don´t know if I can configure Serviio to do AC-3 transcoding just for files with the ".MTS" extension in the filename, is it possible? Otherwise, I think that I have to work on these files and recode it to anything else do make it playable, thanks
Post Thu Mar 17, 2011 1:23 pm
You could try to add this into the profile (transcode to mpegts with ac3 to mpegts with mp3), but you'll lose 5.1 channels (will be stereo)
<Video targetContainer="mpegts" targetACodec="mp3">
  <Matches container="mpegts" aCodec="ac3" />
killer
Post Thu Mar 24, 2011 7:00 pm
thanks for the reply, the MOV files are running ok, and the issue about the MTS file with no audio, I decided to convert it to something else, thanks
