SOLVED - Samsung "please check your connection" disconnect
This disconnection happens on any file after 3+ minutes.
I searched the forums and with Google until I found the solution suggestion from here: http://www.serviio.org/forum/viewtopic.php?f=5&t=21549
This device in the link is a different Samsung device, however.
SYMPTOM: Samsung H-series profile (or later) devices show "please check your connection" and stop play after playing anything longer than 3 minutes. (Serviio connection, however, stays connected.)
SOLUTION: edit the profiles.xml and remark out the "<DeviceDescription>" section to keep all files playing, and to resume play exactly where it last ended, instead of always starting over from the beginning with the generic profile.
EXAMPLE:
OLD:
<DeviceDescription>
<ExtraElements> <sec:ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:ProductCap> <sec:X_ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:X_ProductCap>
</ExtraElements>
</DeviceDescription>
NEW:
<!-- DeviceDescription -->
<!-- ExtraElements> <sec:ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:ProductCap> <sec:X_ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:X_ProductCap>
</ExtraElements -->
<!-- /DeviceDescription -->
I honestly do not know why this problem started when I installed and linked the same files to a 2nd laptop (i.e. Serviio server), since both had the same 1.9 release and the same stored files, and same viewing devices. But at least the solution WORKS!
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
EXAMPLE:
OLD:
<DeviceDescription>
</ExtraElements>
NEW:
</ExtraElements -->
