UE40C6000 and DLNA mac
fbrassin
Post Sun Feb 27, 2011 1:51 pm
Hi all, i'm a really newbe.
I've just installed serviio on my mac book pro, and try to config my serviio server on my mac.
My server seems to be running but i cannot see any DLNA from my TV.
MY tv is connected OK, as if i try to run TVmobili on my mac my tv sees DLNA immediately.
I red this tread viewtopic.php?f=10&t=1642 and i think i'm in the same situation, i tried to disable my firewall, but nothing changes.
I'd like to post the log, but i don't know where to find it.
Can someone give me some hints?
Tnk you.
Fabio
Post Sun Feb 27, 2011 2:01 pm
Re: UE40C6000 and DLNA mac
There is a big section in this forum with HOWTO topics: viewtopic.php?f=5&t=7
fbrassin
Post Sun Feb 27, 2011 2:24 pm
Tnk you, i begin to understand a little. :)
Here is the log.
I hope this can help :)
(149.92 KiB) Downloaded 969 times
Post Sun Feb 27, 2011 2:41 pm
Is 192.168.0.2 the IP of your mac?
There are no incoming requests so there probably is a firewall on your mac blocking port 8895
fbrassin
Post Sun Feb 27, 2011 2:44 pm
Yes, 192.168.0.2 is my mac_book address.
I disabled the firewall on my mac.
Post Sun Feb 27, 2011 2:48 pm
You have other (virtual) network interfaces. Could you try disabling them (propably vmware/parallels) and try again?
fbrassin
Post Sun Feb 27, 2011 2:58 pm
I'm really sorry, but i'm not able to, can you give me some more info on how to do it?
Tnk you very much.
Post Sun Feb 27, 2011 3:20 pm
http://computers.pubkicks.com/disable-n ... n-mac/511/
do that for vmnet1, vmnet8, vnic0, vnic1
don't forget to enable them back after you try it out so that your currently installed sw still works
fbrassin
Post Sun Feb 27, 2011 4:44 pm
Tnx, now it works.
Just another question.
With my sumsung is there a way to fast forward the movie, i tried but with right arrow it goes ahead of 20 sec. is there another way to go faster or for more minutes ahead?
Tnx
Post Sun Feb 27, 2011 4:54 pm
press the arrow for longer time.
so it worked after you disabled the other interfaces?
fbrassin
Post Sun Feb 27, 2011 5:56 pm
Yes, the probem was vmware and parallels as you told.
After disabled all went right.
Tnk you so much.
fbrassin
Post Sun Feb 27, 2011 7:47 pm
I tried all rc botton even long press, but none of them makes movie goes fastforward except right arrow about 20 sec., maybe there is a setting to modify in my pc?
Post Sun Feb 27, 2011 8:26 pm
right arrow for longer time
Post Sun Feb 27, 2011 8:48 pm
nope zip no matter how long you hold the button it only goes in 20sec steps :(
Post Sun Feb 27, 2011 8:57 pm
weird, on my B series Samsung I hold it for 5 seconds and it takes me to the middle of the movie
Post Sun Feb 27, 2011 9:00 pm
nope dont work on c series sadly. :(
fbrassin
Post Mon Feb 28, 2011 7:02 am
Yes, i was afraid it was so.
Post Sat Mar 26, 2011 7:11 pm
Same thing on my Samsung BD-D5300, but if I hold the button to long it stops and just plays at normal speed.
Post Sat Mar 26, 2011 8:37 pm
moltra wrote:Same thing on my Samsung BD-D5300, but if I hold the button to long it stops and just plays at normal speed.
D and C series use same profile so it will be the same :)
