Samsung cant play any files anymore
Vast
Post Tue Nov 28, 2017 10:15 pm
So today I wanted to play a movie on my Samsung Tv by using Serviio as I always do.
The problem is that none of the files works. It did work a couple of weeks ago.
I have made no change to the setup of the tv, files or Serviio.
I discovered that browsing through the folders on the tv, the files are now all named “Filename.MKV.MKV”.
(Filename is just an example)
I checkes the library of the source of the files and there all was named “Filename.MKV”.
What happened?
I really need help to fix this?
Post Wed Feb 07, 2018 5:32 pm
Re: Samsung cant play any files anymore
Miles, stop spamming about DRM or you're going to get banned. He said the media was working in the past.
Sounds like Samsung pushed out a firmware update that messed up their DLNA player. Wouldn't be the first time... :D
Check your Serviio console and make sure the correct profile is selected. You don't say what model TV you have, so can't say which profile you should be on.
freaknik
Post Thu Feb 08, 2018 12:37 pm
atc98092 wrote:Miles, stop spamming about DRM or you're going to get banned. He said the media was working in the past.
Yea, if I was mod I wouldn't even say anything just swing the ban hammer on all phishers and shills. A lot of them here pushing this and vpn, you guys need to waste all of them and their threads.
Imho that's what the ban is for, people like that trying to pull a fast one.
Post Thu Feb 08, 2018 1:11 pm
Actually, after I posted that I discovered more of the same from that person, so they are gone now. ;)
