Empty folder from my mobile
Remtech
Post Fri Feb 23, 2018 3:42 am
Hi
With my Samsung S6 phone and Galaxy tab S2. I see the server, The folder but it's all empty. From my Panasonic TV, all it's OK. Version 1.9.1 on Win 10 64 bits with ServiiDroid 3.5 in my mobile. Why??? UPNP is enable on my router
Thanks for your help
Post Fri Feb 23, 2018 4:43 am
Re: Empty folder from my mobile
When a device connects to Serviio for the first time, Serviio attempts to determine the type of player and assign the correct profile for that player. However, with phones and tablets (and even some other players), identification is often inaccurate, and Serviio either assigned the wrong profile or just leaves it on the generic profile. The problem is that with the wrong profile, Serviio may not recognize your media as playable on that device and therefore shows no media. Serviio does not display media that is judged to be non-playable.
My S8 is shown as unrecognized in the Serviio console, and assigned the generic profile. The only network player I have on the phone is VLC, and it too shows empty lists under Titles and Playlists. However, under Movies and Folders I can see and play everything. So, look under Movies and/or Folders and see what you can find. If you aren't using VLC as your player you might give it a try.
Post Fri Feb 23, 2018 5:12 am
Oh, by the way, I overlooked one other great option for your Android devices. ServiiGo is an Android app designed specifically to work with Serviio. I have it as well, and it shows and plays everything. the one thing is I believe you have to have the Pro version of Serviio for it to connect properly. But it's a great player for your Android device.
