TV UE46C6000 Audio track selection not working
zakko
Post Wed Mar 30, 2011 8:54 am
Hi everyone,
I just installed serviio for the first time (latest version of course) and I can't figure out how to select the audio track in an avi or mkv file with multiple audio tracks...
Any hint or workaround for me??
NOTE: the same files shared with the official samsung dlna server ( I dont' remember even the name) had the possibility to choose the audio track clicking info's button on the TV remote.
Hope it's possible or it will be added soon :)
Post Wed Mar 30, 2011 9:04 am
Re: TV UE46C6000 Audio track selection not working
I didn't know it was possible. Will investigate.
Post Wed Mar 30, 2011 9:37 am
As far as i remember you can select the subtitle language but i havent seen a setting to change the audio language on samsung TV/BDPs.
zakko
Post Wed Mar 30, 2011 10:22 pm
noo you are right... I dont0' knwo what i smoked... I think I confused the option from teh HD with the DLNA teh same file from the USB HD permits me to change teh audio... but from DLNA you are completely right it's not possible... I'm really sorry for this...
Post Thu Mar 31, 2011 11:39 am
zakko wrote:noo you are right... I dont0' knwo what i smoked... I think I confused the option from teh HD with the DLNA teh same file from the USB HD permits me to change teh audio... but from DLNA you are completely right it's not possible... I'm really sorry for this...
Dont be sorry mate it quite alright id rather people posted when things are missing so that we can help ZIP inprove serviio, sadly this time its not possible but please dont be put off and keep posting here and using serviio.
jfcg
Post Sat Apr 02, 2011 6:51 pm
So, is it not possible to change the audio track of a movie? Because this menu option appears in the tv when you have the same file in a usb device. Is a DNLA limitation?
Post Sat Apr 02, 2011 7:51 pm
jfcg wrote:So, is it not possible to change the audio track of a movie? Because this menu option appears in the tv when you have the same file in a usb device. Is a DNLA limitation?
no its not possible to change the audio track, only the subtitle language.
Post Sun Apr 03, 2011 10:18 am
jfcg wrote:Is a DNLA limitation?
most likely
