stability and responsiveness of serviio
a4refillpad
Post Wed Apr 27, 2011 9:23 am
Contrary to everyone else I seem to find the Samsung software a lot more responsive on my ps63c7000 especially when skipping forward/back. So I think there must be something wrong with my config.
Is there anything I can do to tweak this performance? I'm finding that the film drops out when I fast forward/rewing too much on serviio and very often it refuses to play a file on the 1st & 2nd attempts saying the file is unsupported and then it plays on subsequent attempts. The desktop running the software is a nettop running xp home with just an atom processor but the cpu load is always very low.
(additional info: the same thing happens when I use my bluray player too and everything is connected locally via a 100mb/1gbit switch.)
Any help very much appreciated.
Post Wed Apr 27, 2011 9:36 am
Re: stability and responsiveness of serviio
Wired or wireless?
a4refillpad
Post Wed Apr 27, 2011 9:38 am
Have tried wireless in the past but now all wired on a gigabit switch and still the same. I've performed a network test using a fluke device and all is apparently good.
a4refillpad
Post Thu Apr 28, 2011 2:41 pm
any advice from anyone else?
Post Thu Apr 28, 2011 3:37 pm
have you ever tried comparing the transfer rates between the nettop and a full computer. I have a WD My Book World Edition that the actual network interface slows transfers down. The network interface was the weakest link. Do a google search and you should be able to find some freeware that will test the transfer rate. or you could run a download test from http://www.dslreports.com using the same download test location and compare the rates.
a4refillpad
Post Sun May 01, 2011 12:35 am
I've already run an iperf test on the net top interface to my nas and am getting pretty good transfer speeds of 500mbits+ between the devices. I've also recently installed the software on another desktop with a lot more grunt but the situation is only magically better. Am I the only person getting better performance from the original samsung software here?
Post Sun May 01, 2011 2:39 am
a4refillpad wrote:I've already run an iperf test on the net top interface to my nas and am getting pretty good transfer speeds of 500mbits+ between the devices. I've also recently installed the software on another desktop with a lot more grunt but the situation is only magically better. Am I the only person getting better performance from the original samsung software here?
yes
