Samsung/IPad Serviio Browsing problem
mikey81
Post Mon Jun 13, 2011 8:11 am
Hi All,
I have got a problem with browsing the content of Video folders on both my Samsung and the IPad.
When I add the folder containing just the pictures then I can see them showing fine on both devices.
When I add the folder containing video then the only thing is can see is the folder itself and no subfolders or any files.
I have tried 2 different systems Win7 and WinXP and both do the same.
Any clues? Do I need any codecs on my Laptop? Tried 2 different routers as well as connecting both via wireless and wired Ethernet.
Any hints would be most helpful.
Thanks,
Mikey
Post Mon Jun 13, 2011 11:39 am
Re: Samsung/IPad Serviio Browsing problem
It takes a while for serviio to index all your files if you have a large library.
Can you post your serviio.log file on here.
mikey81
Post Tue Jun 14, 2011 11:57 am
all working good now. It was a case of folder ownership on xp/windows7. copying files to other folder and adding it to serviio library solved the problem.
thanks
Post Tue Jun 14, 2011 11:59 am
Glad you got it working.
