ps51d550 issue
soul75
Post Thu Jun 23, 2011 1:44 pm
ps51d550 issue
hi all im back again with another newbie problem.
i have just got a replacement tv for my c680 that had to many issues,so now i have got a ps51d550,and was looking forward to trying out a 3d movie but when i did the sound keeps stuttering for a mil second,this happens all the time on any of my movies i have.
this didnt happen on the c680 it ran with no problems,in the console its showing as a ps51d550 and is green,everything else is the same as before.is this a major problem with my tv and serviio?
i have tried downgrading the sound to stero and no joy,tried rebooting the console ect but no joy.
i am wired to the router as per normal as well.
i am using the lastest version 0.5.2
am i now doomed not to watch a movie,i use sbs mkv movies the video seems ok its just the audio i think.im not a pro at these things so excuse me being dumb. :(
one thing i forgot to ask is i have a ht-c5900 will it run through that,as it has a ethernet port on back and have used it for lovefilm movies?
Post Thu Jun 23, 2011 5:18 pm
Re: ps51d550 issue
soul75 wrote:hi all im back again with another newbie problem.
no sure atm on first bit but yes it should run on the HT-c5900.
soul75
Post Thu Jun 23, 2011 7:15 pm
Re: ps51d550 issue
i have to try using my blueray player then,not to chuffed i cant use my tv to stream me movies across.whats the difference in the 2011 model as this one i got is the newer version of my old c680?
Post Fri Jun 24, 2011 7:14 pm
Re: ps51d550 issue
soul75 wrote:i have to try using my blueray player then,not to chuffed i cant use my tv to stream me movies across.whats the difference in the 2011 model as this one i got is the newer version of my old c680?
dont know i dont own one to test on sry :(
soul75
Post Sat Jun 25, 2011 8:45 am
Re: ps51d550 issue
well i tested 5 mins of a film through my c5900 and seems ok,will try some more later,but one thing is tho that the console does not recongise it as its a yellow dot i have it as c/d tv player one.
anyway to change that to green or does it not matter?
soul75
Post Mon Jun 27, 2011 8:05 am
Re: ps51d550 issue
seems to work fine through blueray player,even tho its showing a yellow dot and not green,watched 3 movies and not one lag or stutter so seems ok.
Post Mon Jun 27, 2011 8:57 am
Re: ps51d550 issue
soul75 wrote:seems to work fine through blueray player,even tho its showing a yellow dot and not green,watched 3 movies and not one lag or stutter so seems ok.
yellow dot not green is not a limitation, only that automatically detection of the profile is not reached
viewtopic.php?f=5&t=1626&p=8441&hilit=library#p8441
Post Mon Jun 27, 2011 12:11 pm
Re: ps51d550 issue
that link is not relevant, Illico ;-) But yep, green means Serviio knows the device is on, yellow means it cannot figure it out (as the device doesn't implement the needed functionality)
Post Mon Jun 27, 2011 12:37 pm
Re: ps51d550 issue
zip wrote:that link is not relevant, Illico ;-)
:lol: :lol: Excellent, sorry I could not find the relevant link...
