Server not launching properly?
roginlon
Post Tue May 31, 2011 10:40 pm
I have just installed Serviio 0.5.2 and installed it on a Mac running OS X 10.6.7. When I launch Server, it bounces in the dock without the blue dot appearing and when I right-click, the status is not responding. However, when I launch Console, it says that the Server is running.
I can add folders on my NAS-HDD in Console and I can see the folder on my Samsung TV with the BD-D8900M Blu-Ray Player when selecting AllShare Serviio as source, but I can not see the video files contained in the folder.
I have re-downloaded and reinstalled the software without improvement. I am confused about where to start the troubleshooting since OS X says Server is not running while Console says it is and I can see a folder deep in the structure on my NAS, but not the files in that folder.
What are the next steps I should take? :? :? :?
Post Tue May 31, 2011 10:55 pm
Re: Server not launching properly?
That is a normal behaviour. It might take some time to index the files. You can check the log to see what files have been added.
roginlon
Post Wed Jun 01, 2011 6:31 am
Thanks for a quick reply. Is it normal behaviour that the Server is in a non-responsive state as well as it taking some time before the files show up on the TV-side?
Post Wed Jun 01, 2011 8:58 am
Yes to the first, the second depends on the size of your library. If you have a shared music folder as well and it is indexing it first you have to wait for all the music to be indexed before it starts indexing any other folders.
roginlon
Post Wed Jun 01, 2011 12:40 pm
Great. I just left it on this morning when I left home so hopefully it will all be ok tonight then. It really is excellent that you have put together this software and I look forward to using it when I get it up and running properly (at which time I will also make a donation). Thank you.
roginlon
Post Wed Jun 01, 2011 10:26 pm
Have now got it to work with a local folder on my hard disk and the sever application is no longer non-responsive.
However, it still does not work with a folder on my NAS. Maybe I am not getting the path right. Is it correct if I right-click on the NAS folder and do Get Info and simply copy the server path (starting with afp://) that it shows, or do I need to use anything else?
Post Wed Jun 01, 2011 10:28 pm
Don't think that is right (I'm not a Mac user mind you). It should be something like /Volumes/xxx for example. Something you can 'cd' to in Terminal.
erin.sutley
Post Thu Jun 30, 2011 5:26 am
I installed Serviio (0.5.2) on my Mac (OSX 10.6.8) a couple of days ago and I noticed that I had the same issue that the serviio.app would not respond. I left it open as it says that I should, but I have left for over 24 hours and there is still no change. And when I check the log the last thing is has is the following line:
2011-06-29 02:18:45,503 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Does anyone know what I can do to get this working?
Post Thu Jun 30, 2011 8:29 am
That's expected. Serviio.app is the server itself, Serviio-Console.app is the configuration console (use that to add shared folders)
