Transcode failure
Post Mon Jul 04, 2011 4:19 am
Transcode failure
I know by testing that my Samsung D will play .flv container files (video/x-flv) containing h264(avc) video and aac audio streams.
According to the Transcoding Config document, this entry in the Samsung 7 Profile will transcode any flv with an h264(avc) codec regardless of the audio to an mpegts with a copied h264 video and a converted ac3 audio.
When I play one of these videos using this rule, the mime displays as video/mpeg and the skip forward/back is disabled.
To work around this I first tried
<Video targetContainer="mpeg" targetACodec="ac3">
then
<Video targetContainer="asf" targetACodec="ac3">
Both of these are valid Samsung file formats but DLNA gave me "unsupported file format" errors.
Is Mpegts the only container I can transcode to?
Post Mon Jul 04, 2011 12:01 pm
Re: Transcode failure
you have to provide targetVCodec="mpeg2video" for the mpeg case, mpegPS only allows mpeg2 video stream, not h264. Obviously more CPU will be used in this case.
