Samsung LE32C550
RaM419
Post Mon Nov 14, 2011 5:48 pm
Samsung LE32C550
I have Samsung LE32C550 TV connected via Canyon CNP-wf514N3A router to Netgear WNA3100 wifi dongle on PC.
I can play this:
Count                            : 278
Count of stream of this kind     : 1
Kind of stream                   : General
Stream identifier                : 0
Inform                           : AVI: 15.9 MiB, 30s 0ms
Count of video streams           : 1
Count of audio streams           : 1
Video_Format_List                : JPEG
Video_Format_WithHint_List       : JPEG
Codecs Video                     : JPEG
Audio_Format_List                : PCM
Audio_Format_WithHint_List       : PCM
Audio codecs                     : PCM
Complete name                    : F:\testfiles\A70.avi
Folder name                      : F:\testfiles
File name                        : A70
File extension                   : avi
Format                           : AVI
Format                           : AVI
Format/Info                      : Audio Video Interleave
Format/Extensions usually used   : avi
Commercial name                  : AVI
Internet media type              : video/vnd.avi
Interleaved                      : Yes
Codec                            : AVI
Codec                            : AVI
Codec/Info                       : Audio Video Interleave
Codec/Extensions usually used    : avi
File size                        : 16698526
File size                        : 15.9 MiB
File size                        : 16 MiB
File size                        : 16 MiB
File size                        : 15.92 MiB
Duration                         : 30000
Duration                         : 30s 0ms
Duration                         : 30s 0ms
Duration                         : 30s 0ms
Duration                         : 00:00:30.000
Overall bit rate                 : 4452940
Overall bit rate                 : 4 453 Kbps
Stream size                      : 13588
Stream size                      : 13.3 KiB (0%)
Stream size                      : 13 KiB
Stream size                      : 13.27 KiB
Proportion of this stream        : 0.00081
Mastered date                    : Wed Apr 05 16:51:28 2006
File creation date               : UTC 2011-11-08 18:26:15.339
File creation date (local)       : 2011-11-08 19:26:15.339
File last modification date      : UTC 2006-04-05 14:51:30.000
File last modification date (loc : 2006-04-05 15:51:30.000
Writing application              : CanonMVI01
Count                            : 201
Kind of stream                   : Video
Inform                           : 4 361 Kbps, 640*480 (4:3), at 15.000 fps, JPEG
Format                           : JPEG
Commercial name                  : JPEG
Internet media type              : video/JPEG
Codec ID                         : MJPG
Codec                            : MJPG
Codec                            : JPEG
Codec/Family                     : JPEG
Codec/Info                       : JPEG including Huffman Tables
Codec/CC                         : MJPG
Duration                         : 30000
Duration                         : 30s 0ms
Duration                         : 30s 0ms
Duration                         : 30s 0ms
Bit rate                         : 4361125
Bit rate                         : 4 361 Kbps
Width                            : 640
Width                            : 640 pixels
Height                           : 480
Height                           : 480 pixels
Pixel aspect ratio               : 1.000
Display aspect ratio             : 1.333
Display aspect ratio             : 4:3
Frame rate                       : 15.000
Frame rate                       : 15.000 fps
Frame count                      : 450
Resolution                       : 8
Resolution                       : 8 bits
Chroma subsampling               : 4:2:2
Bit depth                        : 8
Interlacement                    : PPF
Interlacement                    : Progressive
Bits/(Pixel*Frame)               : 0.946
Stream size                      : 16354218
Stream size                      : 15.6 MiB (98%)
Stream size                      : 16 MiB
Stream size                      : 15.60 MiB
Proportion of this stream        : 0.97938
Count                            : 169
Kind of stream                   : Audio
Inform                           : 88.2 Kbps, 11.024 KHz, 8 bits, 1 channel, PCM (Unsigned)
Format                           : PCM
Commercial name                  : PCM
Format settings                  : Unsigned
Format settings, Sign            : Unsigned
Codec ID                         : 1
Codec ID/Url                     : http://www.microsoft.com/windows/
Codec                            : PCM
Codec                            : PCM
Codec/Family                     : PCM
Codec/Info                       : Microsoft PCM
Codec/Url                        : http://www.microsoft.com/windows/
Codec/CC                         : 1
Codec settings                   : Unsigned
Codec settings, Sign             : Unsigned
Duration                         : 30000
Duration                         : 30s 0ms
Duration                         : 30s 0ms
Duration                         : 30s 0ms
Bit rate mode                    : CBR
Bit rate                         : 88200
Bit rate                         : 88.2 Kbps
Channel(s)                       : 1
Channel(s)                       : 1 channel
Sampling rate                    : 11024
Sampling rate                    : 11.024 KHz
Samples count                    : 330720
Frame count                      : 330720
Resolution                       : 8
Resolution                       : 8 bits
Bit depth                        : 8
Stream size                      : 330720
Stream size                      : 323 KiB (2%)
Stream size                      : 323.0 KiB
Proportion of this stream        : 0.01981
Interleave, duration             : 15.00
Interleave, duration             : 1000
Interleave, duration             : 1000 ms (15.00 video frames)
Interleave, preload duration     : 1000
Interleave, preload duration     : 1000 ms
C:\Program Files\Serviio\lib>ffmpeg -i "f:\testfiles\a70.avi"
nfig
Input #0, avi, from 'f:\testfiles\a70.avi':
    creation_time   : 2006-04-05 16:51:28
    encoder         : CanonMVI01
  Duration: 00:00:29.99, start: 0.000000, bitrate: 4452 kb/s
    Stream #0.0: Video: mjpeg, yuvj422p, 640x480, 15 tbr, 15 tbn, 15 tbc
    Stream #0.1: Audio: pcm_u8, 11024 Hz, 1 channels, u8, 88 kb/s
but not:
Count                            : 278
Inform                           : MPEG-4 (QuickTime): 78.3 MiB, 18s 727ms
Video_Format_List                : AVC
Video_Format_WithHint_List       : AVC
Codecs Video                     : AVC
Video_Language_List              : English
Audio codecs                     : PCM
Audio_Language_List              : English
Complete name                    : F:\testfiles\HS220.mov
File name                        : HS220
File extension                   : mov
Format                           : MPEG-4
Format                           : MPEG-4
Format/Extensions usually used   : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
Commercial name                  : MPEG-4
Format profile                   : QuickTime
Internet media type              : video/mp4
Codec ID                         : qt
Codec ID/Url                     : http://www.apple.com/quicktime/download/standalone.html
Codec                            : MPEG-4
Codec                            : MPEG-4
Codec/Extensions usually used    : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
File size                        : 82067532
File size                        : 78.3 MiB
File size                        : 78 MiB
File size                        : 78 MiB
File size                        : 78.27 MiB
Duration                         : 18727
Duration                         : 18s 727ms
Duration                         : 00:00:18.727
Overall bit rate                 : 35058485
Overall bit rate                 : 35.1 Mbps
Stream size                      : 98312
Stream size                      : 96.0 KiB (0%)
Stream size                      : 96 KiB
Stream size                      : 96.01 KiB
Proportion of this stream        : 0.00120
HeaderSize                       : 98304
DataSize                         : 81969228
FooterSize                       : 0
IsStreamable                     : Yes
Encoded date                     : UTC 2011-10-01 09:42:21
Tagged date                      : UTC 2011-10-01 09:42:21
File creation date               : UTC 2011-11-08 18:24:04.745
File creation date (local)       : 2011-11-08 19:24:04.745
File last modification date      : UTC 2011-10-01 10:42:22.000
File last modification date (loc : 2011-10-01 11:42:22.000
Count                            : 204
Inform                           : English, 33.5 Mbps, 1920*1080 (16:9), at 23.976 fps, AVC (Baseline@L5.0) (1 Ref Frames)
Format/Url                       : http://developers.videolan.org/x264.html
Commercial name                  : AVC
Format profile                   : Baseline@L5.0
Format settings                  : 1 Ref Frames
Format settings, CABAC           : No
Format settings, ReFrames        : 1
Format settings, ReFrames        : 1 frame
Format settings, GOP             : M=1, N=12
Internet media type              : video/H264
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Codec                            : AVC
Codec                            : AVC
Codec/Family                     : AVC
Codec/Info                       : Advanced Video Codec
Codec/Url                        : http://developers.videolan.org/x264.html
Codec/CC                         : avc1
Codec profile                    : Baseline@L5.0
Codec settings                   : 1 Ref Frames
Codec settings, CABAC            : No
Codec_Settings_RefFrames         : 1
Duration                         : 18727
Bit rate                         : 33480376
Bit rate                         : 33.5 Mbps
Width                            : 1920
Width                            : 1 920 pixels
Height                           : 1080
Height                           : 1 080 pixels
Display aspect ratio             : 1.778
Rotation                         : 0.000
Frame rate mode                  : CFR
Frame rate mode                  : Constant
Frame rate                       : 23.976
Frame rate                       : 23.976 fps
Frame count                      : 449
Resolution                       : 8
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Bit depth                        : 8
Interlacement                    : PPF
Bits/(Pixel*Frame)               : 0.673
Stream size                      : 78373628
Stream size                      : 74.7 MiB (95%)
Stream size                      : 75 MiB
Stream size                      : 74.74 MiB
Proportion of this stream        : 0.95499
Language                         : en
Language                         : English
Language                         : English
Language                         : en
Language                         : eng
Language                         : en
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Count                            : 169
Inform                           : English, 1 536 Kbps, 48.0 KHz, 16 bits, 2 channels, PCM (Little / Signed)
Format                           : PCM
Format settings                  : Little / Signed
Format settings, Endianness      : Little
Format settings, Sign            : Signed
Codec ID                         : sowt
Codec                            : PCM
Codec                            : PCM
Codec/Family                     : PCM
Codec/Url                        : http://www.apple.com/quicktime/download/standalone.html
Codec/CC                         : sowt
Codec settings                   : Little / Signed
Codec settings, Endianness       : Little
Codec settings, Sign             : Signed
Duration                         : 18727
Bit rate mode                    : CBR
Bit rate                         : 1536000
Bit rate                         : 1 536 Kbps
Channel(s)                       : 2
Channel(s)                       : 2 channels
Channel positions                : Front: L R
ChannelLayout                    : L R
Sampling rate                    : 48000
Samples count                    : 898896
Frame count                      : 898896
Resolution                       : 16
Resolution                       : 16 bits
Bit depth                        : 16
Bit depth                        : 16 bits
Stream size                      : 3595592
Stream size                      : 3.43 MiB (4%)
Stream size                      : 3 MiB
Stream size                      : 3.4 MiB
Stream size                      : 3.429 MiB
Proportion of this stream        : 0.04381
Language                         : en
Language                         : English
Language                         : English
Language                         : en
Language                         : eng
Language                         : en
C:\Program Files\Serviio\lib>ffmpeg -i "f:\testfiles\hs220.mov
nfig
Seems stream 0 codec frame rate differs from container frame rate: 48000.00 (480
00/1) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'f:\testfiles\hs220.mov':
    major_brand     : qt
    minor_version   : 537331968
    compatible_brands: qt  CAEP
    creation_time   : 2011-10-01 09:42:21
  Duration: 00:00:18.72, start: 0.000000, bitrate: 35058 kb/s
    Stream #0.0(eng): Video: h264 (Constrained Baseline), yuvj420p, 1920x1080, 3
3480 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 48k tbc
    Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
and also can not:
Count                            : 278
Inform                           : AVI (DVCPRO): 29.8 MiB, 8s 160ms
Video_Format_List                : DV
Video_Format_WithHint_List       : DV (Sony)
Codecs Video                     : Sony DV
Audio codecs                     : PCM
Complete name                    : F:\testfiles\sonycamera.avi
File name                        : sonycamera
Format                           : AVI
Format                           : AVI
Commercial name                  : AVI DVCPRO
Format_Commercial_IfAny          : DVCPRO
Interleaved                      : Yes
Codec                            : AVI
Codec                            : AVI
File size                        : 31262208
File size                        : 29.8 MiB
File size                        : 30 MiB
File size                        : 30 MiB
File size                        : 29.81 MiB
Duration                         : 8160
Duration                         : 8s 160ms
Duration                         : 8s 160ms
Duration                         : 8s 160ms
Duration                         : 00:00:08.160
Overall bit rate mode            : CBR
Overall bit rate mode            : Constant
Overall bit rate                 : 30649223
Overall bit rate                 : 30.6 Mbps
Stream size                      : 319488
Stream size                      : 312 KiB (1%)
Stream size                      : 312.0 KiB
Proportion of this stream        : 0.01022
Recorded date                    : 2011-05-13 09:29:05.000
File last modification date      : UTC 2011-05-13 07:29:00.000
File last modification date (loc : 2011-05-13 08:29:00.000
Count                            : 201
Inform                           : 24.4 Mbps, 720*576 (16:9), at 25.000 fps, DV (Sony) (PAL) (DVCPRO)
Format                           : DV
Commercial name                  : DVCPRO
Internet media type              : video/DV
Codec ID                         : dvsd
Codec ID/Hint                    : Sony
Codec                            : dvsd
Codec                            : Sony DV
Codec/Family                     : DV
Codec/Info                       : Sony DV (DV) 525 lines at 29.97 Hz or 625 lines at 25.00 Hz
Codec/CC                         : dvsd
Duration                         : 8160
Duration                         : 8s 160ms
Duration                         : 8s 160ms
Duration                         : 8s 160ms
Bit rate mode                    : CBR
Bit rate                         : 24441600
Bit rate                         : 24.4 Mbps
Width                            : 720
Width                            : 720 pixels
Height                           : 576
Height                           : 576 pixels
Pixel aspect ratio               : 1.422
Frame rate                       : 25.000
Frame rate                       : 25.000 fps
Frame count                      : 204
Standard                         : PAL
Resolution                       : 8
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Bit depth                        : 8
Scan type                        : Interlaced
Interlacement                    : Interlaced
Bits/(Pixel*Frame)               : 2.357
Delay                            : 849680
Delay                            : 14mn 9s
Delay                            : 14mn 9s 680ms
Delay                            : 14mn 9s
Delay                            : 00:14:09.680
Delay, origin                    : Stream
Delay, origin                    : Raw stream
Stream size                      : 29376000
Stream size                      : 28.0 MiB (94%)
Stream size                      : 28 MiB
Stream size                      : 28.02 MiB
Proportion of this stream        : 0.93966
Encoding settings                : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
Count                            : 169
Inform                           : 1 536 Kbps, 48.0 KHz, 16 bits, 2 channels, PCM (Little / Signed)
Format                           : PCM
Codec ID                         : 1
Codec                            : PCM
Codec                            : PCM
Codec/Family                     : PCM
Codec/CC                         : 1
Duration                         : 8160
Duration                         : 8s 160ms
Duration                         : 8s 160ms
Duration                         : 8s 160ms
Bit rate mode                    : CBR
Bit rate                         : 1536000
Channel(s)                       : 2
Samples count                    : 391680
Frame count                      : 391680
Resolution                       : 16
Bit depth                        : 16
Bit depth                        : 16 bits
Stream size                      : 1566720
Stream size                      : 1.49 MiB (5%)
Stream size                      : 1 MiB
Stream size                      : 1.5 MiB
Stream size                      : 1.494 MiB
Proportion of this stream        : 0.05012
Interleave, duration             : 1.00
Interleave, duration             : 40
Interleave, duration             : 40 ms (1.00 video frame)
Microsoft Windows XP [Verze 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Program Files\Serviio\lib>ffmpeg -i "f:\testfiles\sonycamera.avi"
nfig
Input #0, avi, from 'f:\testfiles\sonycamera.avi':
  Duration: 00:00:08.16, start: 0.000000, bitrate: 30649 kb/s
    Stream #0.0: Video: dvvideo, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 25 tbr,
25 tbn, 25 tbc
    Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
I set C profile on Serviio on 192.168.1.100, showing that TV is not known.
Any hints?
Rastislav.
Post Tue Nov 15, 2011 8:16 am
Re: Samsung LE32C550
AVC/h264 Format profile : Baseline@L5.0 NOT supported must be MPEG2 transcoded.
dvvideo will be supported on next serviio release : https://bitbucket.org/xnejp03/serviio/i ... ideo-codec
Post Tue Nov 15, 2011 10:14 am
dvvideo is supported in 0.6. Maybe the transcoding setting is missing.
RaM419
Post Fri Nov 18, 2011 4:10 pm
The transcoding is now on.
MOV files not supported, for the AVI (now playing for few seconds) I am getting "connection lost" even the connection is available...
Post Fri Nov 18, 2011 4:24 pm
any errors during the transcode in the log? enable detailed log, find the ffmpeg command used for transcode and try to run it manually
RaM419
Post Sat Nov 19, 2011 6:50 pm
After update, here is the code of LOG:
I see no error, also manual ffmpeg command is without error.
(143.07 KiB) Downloaded 659 times
Post Sun Nov 20, 2011 11:37 am
the log doesn't show any browsing/playing of the avi files, it only shows how your files have been added to the library
RaM419
Post Mon Nov 21, 2011 6:28 pm
first file was played without troubles,
2 additional files ends with error on TV: no codec supported
please see the log file again.
transcoding enabled.
with errors
(64.94 KiB) Downloaded 630 times
Post Tue Nov 22, 2011 11:26 am
you are using Generic profile for this player: 192.168.1.102. Set up static IP addresses for your devices and assign the right profile.
