one file missing!?
selector007
Post Wed Jan 11, 2012 10:58 pm
one file missing!?
I've been using Serviio for a while now and i think its great but recently i have come across a file which will not show up in the movies folder. I can view the file if i open it via the 'folder' option but it does not appear in the movies folder. The file is a mp4 format.
Any Ideas?
Samsung 40D7000
Post Wed Jan 11, 2012 11:08 pm
Re: one file missing!?
metadata for it couldn;t be found. try to rename the file and check the title exists on themoviedb.org
selector007
Post Thu Jan 12, 2012 11:50 am
I have checked the file on the movie database website and the movie is in the library also i have renamed the file but still it does not show up in movies folder. However via the folder view the movie is there with the correct thumbnail pic so the file is picking up the correct metadata?
Any ideas?
Samsung 40D7000
Post Thu Jan 12, 2012 1:38 pm
thumbnail pic being the DVD cover or a snapshot from the video?
selector007
Post Thu Jan 12, 2012 8:38 pm
it appears to be the dvd cover?
Samsung 40D7000
selector007
Post Fri Jan 13, 2012 4:57 pm
The movie has now appeared in the folder MOVIES but is there anyway i can rename the file as it isn't correct?
Samsung 40D7000
Post Fri Jan 13, 2012 4:59 pm
you have to change file name to match whatever it's called on themoviedb.org
selector007
Post Sat Jan 14, 2012 10:58 am
That seemed to do the trick. But its strange as sometimes the filename isn't anything like whats on moviedb.org but it finds it?
Samsung 40D7000
Post Sat Jan 14, 2012 9:23 pm
yeah well Serviio is trying its best to guess the name but obviously it is not 100% right
Post Sun Jan 15, 2012 8:03 am
http://wiki.serviio.org/doku.php?id=therenamer <-- sort your Movie and TV Series filenames the easy way with this handy tool
