HD MPEG files will not seek.
matthelm
Post Tue Jan 17, 2012 3:21 am
I'm trying to playback ClearQAM recorded TV. I'm using SageTV with a HDHomeRun to make these recordings. The files play fine, but I can not use the FF, REW, or Time Search.
Anyone out there know a fix for this?
Here is Media Info dump of one of the files:
Complete name : \\DAVERECORDER\Shows1\HowIMetYourMother-S07E13-Tailgate-10057488-0.mpg
Format : MPEG-PS
File size : 3.67 GiB
Duration : 30mn 46s
Overall bit rate : 17.1 Mbps
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 30mn 46s
Bit rate mode : Variable
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Audio #2
Format : AC-3
Audio #3
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Muxing mode : DVD-Video
Duration : 30mn 46s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -802ms
Stream size : 84.5 MiB (2%)
Audio #4
ID : 189 (0xBD)-129 (0x81)
Format : AC-3
Duration : 30mn 46s
Bit rate : 192 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Delay relative to video : -764ms
Stream size : 42.3 MiB (1%)
Text #1
ID : 224 (0xE0)-608-1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
Post Tue Jan 17, 2012 5:53 am
Re: HD MPEG files will not seek.
MPEG files on Samsung D series will not seek on DLNA....Major defeciency..see my other posts. This is a Samsung problem, not Serviio.
matthelm
Post Sun Jan 22, 2012 5:45 am
jhb50 wrote:MPEG files on Samsung D series will not seek on DLNA....Major defeciency..see my other posts. This is a Samsung problem, not Serviio.
Any easy way to contact Samsung?
Post Sun Jan 22, 2012 8:04 am
rofl easy and contact samsung, never meet, it is always a battle to contact samsung for support.
skug67
Post Wed Jan 25, 2012 1:11 am
I'm having similar problems and had hoped that I might be able to solve it by transcoding (on the fly) to a lower res mpg file. But nothing I've tried works.
It's a major bummer because one of the things I would really like to be able to do is use my HDHomerun, MythTv, Serviio and my Samsung C series TV to "catch up" with a football/basketball/baseball game already in progress (a typical Tivo usage) and I can't quite manage to do it. Any suggestions??? (I'm more than willing to add/change software -- at least if it's open source and can run on a linux (debian) box)
Post Wed Jan 25, 2012 12:58 pm
skug67 wrote:Any suggestions???
Try remuxing the mpegPS (program stream) to MPEGTS (transport stream).
skug67
Post Wed Jan 25, 2012 1:42 pm
I thought the HDHR produced TS. In fact, I'm pretty sure one of the "fixes" I'd tried was remuxing from TS to PS. I'll double check tonight when I get home.....
Post Wed Jan 25, 2012 1:58 pm
If you find a way please post it. It impacts anything that is transcoded.
skug67
Post Wed Jan 25, 2012 9:50 pm
I was able to confirm that the HDHomeRun (at least when invoked by MythTV) does produce an MPEGTS file. So that doesn't seem to be the problem. (In fact, if I use MythTV's prepackaged script for removing commercials it has the byproduct of converting the file to PS which actually seems to improve the seeking. Which I why I had previously tried on the fly TS-to-PS remuxing to see if it would solve my problem (and it didn't)).
