Problems with Youtube 1080p videos
TheOne.PC
Post Wed Feb 08, 2012 7:37 pm
Referring to this viewtopic.php?p=36926#p36926
I open a new thread here because zip told me to do so.
I've added this RSS feed
http://gdata.youtube.com/feeds/api/user ... ll/uploads
But why can I play this video (highest quality 720p)
http://www.youtube.com/watch?v=JqbgOK52 ... uKJz_2ud68
and I can't play this video (highest quality 1080p)
http://www.youtube.com/watch?v=rMmRBNDA ... rQeYgTsV2A
In the simplified log file I've found this
2012-02-06 18:51:32,400 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
2012-02-06 18:52:16,936 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-02-06 18:52:37,721 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
Attached the log with debug turned on
The TV says "video codec not supported" and skips to next video
serviio.log.zip
(56.49 KiB) Downloaded 680 times
Post Wed Feb 08, 2012 11:20 pm
Re: Problems with Youtube 1080p videos
As zip already told you the log you provided does not contain those error messages. It in fact shows that all the YT videos were correctly parsed and added to Serviio and should play fine.
Additionally I have tested your yt gdata link and all 25 videos display in Serviio and play fine.
The youtube links you have quoted however cannot be used in Serviio. They must be of the gdata for as explained in the wiki.
TheOne.PC
Post Wed Feb 08, 2012 11:47 pm
jhb50 wrote:As zip already told you the log you provided does not contain those error messages. It in fact shows that all the YT videos were correctly parsed and added to Serviio and should play fine.
So why can YOU see all the video?
Why is there the error in the simple log, but not in the debug log?
The problem came after upgrading to 0.6.1
(The youtube direct link i posted were only for understand what video i try to play in the rss feed)
Post Thu Feb 09, 2012 12:31 am
How could I know without seeing the "simple" log. Can't fix what we can't see.
If you are using the 2/7 groovy then it should work fine. Check that this line is in your groovy
    final availableFormats = ['37', '46', '22', '45', '35', '34', '18', '44', '43', '6', '5']
Until we can see what is broken, we can't tell you what to fix.
What is your TV model, and what profile is Serviio using for it?
TheOne.PC
Post Thu Feb 09, 2012 8:59 am
The simple log is pasted in the first post
I'm using the latest groovy
I've got Samsung c5100
I'm using standard c/d profile
Thanks a lot
Post Thu Feb 09, 2012 9:55 am
also are you on 0.6.2?
TheOne.PC
Post Thu Feb 09, 2012 10:52 am
zip wrote:also are you on 0.6.2?
Yes 0.6.2 on Linux
The problem came when i updated to 0.6.1 and is still in 0.6.2
TheOne.PC
Post Thu Feb 09, 2012 12:50 pm
This is the extended log
And the errors are present
I think there is a FFMPEG problem
serviio.log.zip
(32.64 KiB) Downloaded 656 times
Post Thu Feb 09, 2012 1:34 pm
I'm sorry that I'm unable to give you any help. The log is error free and your groovy contents are unconfirmed so I have nothing to work with.
TheOne.PC
Post Thu Feb 09, 2012 2:21 pm
Attached the groovy I use
In the log i've posted in the post before your there is the error ( viewtopic.php?p=37363#p37363 )
Youtube.groovy
(6.68 KiB) Downloaded 700 times
TheOne.PC
Post Fri Feb 10, 2012 2:15 pm
Jhb50 did you see the error in the log and the groovy?
Post Fri Feb 10, 2012 2:37 pm
There is no error in any of your logs. They are all debug logs.
Your groovy is the latest, so everything should work.
TheOne.PC
Post Fri Feb 10, 2012 4:40 pm
Is not a ffmpeg error?
Post Sat Feb 11, 2012 12:05 am
but it's not in one of the latest detailed logs, in those the file streams and ffmpeg doesn't fail, right?
Post Sat Feb 11, 2012 12:27 am
Posting that line in the original post and quoting it again does not constitute a log file, and none ofthe logs you have posted contain an error. I don't have any more time to spend going round and round with you on this.
TheOne.PC
Post Sat Feb 11, 2012 6:02 pm
jhb50 wrote:Posting that line in the original post and quoting it again does not constitute a log file, and none ofthe logs you have posted contain an error. I don't have any more time to spend going round and round with you on this.
Thanks a lot
Bye
TheOne.PC
Post Sat Feb 11, 2012 6:04 pm
zip wrote:but it's not in one of the latest detailed logs, in those the file streams and ffmpeg doesn't fail, right?
I don't know if ffmpeg fail or not, i can only attach the log i obtain and tell you that the tv say codec not supported and skips
And i can tell you that this problem don't exist for me with 0.6 version of serviio and related ffmpeg.
Thanks for your help
Post Tue Feb 14, 2012 7:29 pm
It your TV's firmware up-to-date?
TheOne.PC
Post Tue Feb 14, 2012 11:26 pm
zip wrote:It your TV's firmware up-to-date?
if i run the update on the tv it says that i'm at the latest firmware
TheOne.PC
Post Mon Feb 20, 2012 12:49 pm
Is it possible that i've got problems with LAVF?
The second time that i compile X264 following the guide
teo@hp-ubuntu:~/src/x264$ ./configure --enable-static
platform:      X86
system:        LINUX
cli:           yes
libx264:       internal
shared:        no
static:        yes
asm:           yes
interlaced:    yes
avs:           no
lavf:          no
ffms:          no
gpac:          no
gpl:           yes
thread:        posix
filters:       resize crop select_every
debug:         no
gprof:         no
strip:         no
PIC:           no
visualize:     no
bit depth:     8
chroma format: all
You can run 'make' or 'make fprofiled' now.
It seems that it doesn't detect LAVF support
