Usupported video data - Samsung UE55B7070WW
primary
Post Mon Feb 13, 2012 8:25 pm
I have a problem that a few of my x264 rips or mkv files will not play. And i get the error unsupported video data.
A specific file that wont play:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\Movies\Share\x264\Puss In B
oots 2011 1080p.mkv
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (500000
0/104271) -> 48.00 (48/1)
Input #0, matroska,webm, from 'E:\Movies\Share\x264\Puss In Boots 2011 1080p.mkv
Duration: 01:30:14.56, start: 0.000000, bitrate: 6934 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x816, SAR 1:1 DAR 40:17,
23.98 fps, 48 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 640 kb/s (default)
Stream #0:2(eng): Subtitle: text (default)
Stream #0:3(eng): Subtitle: text
I have not made a profile for serviio, simply because i just dont understand how to.
I did try to use Intel UPnP tools, it did not find my device.
I also used http://www.dlna.org/consumer-home/look- ... uct-search but my device did not show up there..
URL to the device support info:
http://www.samsung.com/no/support/model ... -techspecs
NOTE!! This product info is in Norwegian. It was not possible to find in English..
Any one have any ideas?
Post Mon Feb 13, 2012 8:30 pm
Re: Usupported video data - Samsung UE55B7070WW
samsung B series profile is part of serviio as default just select it for your device in teh serviio console.
primary
Post Mon Feb 13, 2012 8:41 pm
Hi Phil,
Actually it was selected pr default. But still it does not make any change on my playback.
Post Tue Feb 14, 2012 6:21 am
primary wrote:Hi Phil,
ok one for ZIP then as he has a B series and he wrote the profile. :)
Post Tue Feb 14, 2012 6:46 am
Did you restart serviio? Also please attach your serviio.log file.
primary
Post Sun Feb 19, 2012 1:51 pm
The file in trying to play is named:
mhd-pib-720p.mkv
Logg file attached, log level set to debug.
Any Ideas?
Serviio was restarted before trying to play the file.
(352.39 KiB) Downloaded 739 times
primary
Post Tue Feb 21, 2012 1:16 pm
No one?
Post Tue Feb 21, 2012 1:21 pm
turn off transcoding in the serviio console and try and play the file again does it work ?
if it does then use this tool http://wiki.serviio.org/doku.php?id=avceditor to change the profile level to 4.1 and then turn transcoding on again, and try to play file again.
Post Tue Feb 21, 2012 1:26 pm
This mkv file is delivered in native format.
Could you provide MediaInfo tool result ?
We'll check that h264 profile level < 4.2 and there are no compression header used.
