Problem with H264 (High 10) - Samsung UN55D7000
fpozzatti
Post Tue May 15, 2012 11:50 am
I can't play a mkv file encoded with H264 (High 10) on my UN55D7000.
I receive a "Unsupported codec" on my Samsung TV.
Using Serviio on a Windows 7 Ultimate.
Thanks for support.
ffmpeg version N-40593-g6d37634 Copyright (c) 2000-2012 the FFmpeg developers
built on May 11 2012 12:16:39 with gcc 4.6.3
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass
--enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable
-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope
njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth
eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-
libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e
nable-zlib
libavutil 51. 50.100 / 51. 50.100
libavcodec 54. 21.101 / 54. 21.101
libavformat 54. 4.100 / 54. 4.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 72.105 / 2. 72.105
libswresample 0. 11.100 / 0. 11.100
Input #0, matroska,webm, from 'c:\Users\fabio\Videos\J-Pop\L'Arc~en~Ciel\L'Arc~e
n~Ciel - 20th L'Anniversary LIVE.720p.HDTV.x264-UAC.mkv':
title : L'Arc~en~Ciel - 20th L'Anniversary LIVE.720p.HDTV.x264-UAC
creation_time : 2011-11-09 03:40:15
Duration: 01:55:39.98, start: 0.000000, bitrate: 9331 kb/s
Chapter #0.0: start 189.898000, end 529.904000
title : In the Air
Chapter #0.1: start 529.904000, end 802.218000
title : Caress of Venus
Chapter #0.2: start 802.218000, end 1129.879000
title : Dune
Chapter #0.3: start 1129.879000, end 1492.700000
title : Blurry Eyes
Chapter #0.4: start 1492.700000, end 1844.134000
title : Lies and Truth
Chapter #0.5: start 1844.134000, end 2144.768000
title : flower
Chapter #0.6: start 2144.768000, end 2472.845000
title : Shout at the Devil
Chapter #0.7: start 2472.845000, end 2968.424000
title : ÒüéÒü¬Òüƒ
Chapter #0.8: start 2968.424000, end 3443.231000
title : ÞÖ╣
Chapter #0.9: start 3443.231000, end 3783.238000
title : READY STEADY GO
Chapter #0.10: start 3783.238000, end 4021.809000
title : HEAVEN'S DRIVE
Chapter #0.11: start 4021.809000, end 4322.735000
title : Driver's High
Chapter #0.12: start 4322.735000, end 4571.108000
title : DRINK IT DOWN
Chapter #0.13: start 4571.108000, end 4849.553000
title : µÁ©Úúƒ -lose control-
Chapter #0.14: start 4849.553000, end 5167.245000
title : STAY AWAY
Chapter #0.15: start 5167.245000, end 5461.205000
title : Link
Chapter #0.16: start 5461.205000, end 5869.947000
title : þ×│Òü«õ¢Åõ║║
Chapter #0.17: start 5869.947000, end 6380.499000
title : GOOD LUCK MY WAY
Chapter #0.18: start 6380.499000, end 6939.989000
title : BLESS
Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1280x720, SAR 1:1 DAR
16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(jpn): Audio: aac, 48000 Hz, stereo, s16 (default)
Post Tue May 15, 2012 2:24 pm
Re: Problem with H264 (High 10) - Samsung UN55D7000
Could you enable detailed logging and post here ?
Its probably due to a ffmpeg crash...
fpozzatti
Post Tue May 15, 2012 2:30 pm
All movies encoded with H264 (High 10) can't streaming on my TV.
I will provide the detailed log tomorrow.
Thanks for the help.
Post Tue May 15, 2012 2:38 pm
No the problem is described in here viewtopic.php?f=5&t=6106
Basically, the high 10 videos are not picked up as needing transcoding, as serviio currently looks for baseline, main or high profiles, not high 10.
The easy option is to select the DirecTV HD-DVR profile, which will transcode everything, but that isn't great.
The proper solution would be for zip to add support for selecting videos for transcoding if their h264 profile is high 10, which hopefully wouldn't be too much effort as it can already detect baseline, main and high.
@zip - would this be an easy fix to add for 1.0, or is it more complicated that adding the extra h264 profile option to the xml dtd and updating the code to support it and the required detection?
Edit issue created https://bitbucket.org/xnejp03/serviio/i ... 10p-videos
Post Tue May 15, 2012 4:42 pm
will do it post 1.0
Users browsing this forum: Baidu [Spider] and 17 guests
