stream ogm?
molitar
Post Sat Jul 07, 2012 10:28 am
stream ogm?
When I try to play .ogm file I get the message cannot play video: no streaming url available.
Post Mon Jul 09, 2012 12:31 pm
Re: stream ogm?
post detailed log please
molitar
Post Mon Jul 09, 2012 12:48 pm
Re: stream ogm?
Ok here is the logs.
log.zip
(190.65 KiB) Downloaded 463 times
Post Mon Jul 09, 2012 4:59 pm
Re: stream ogm?
Which profile are you using? Also this is not detailed log. Check out my signature.
molitar
Post Tue Jul 10, 2012 2:47 am
Re: stream ogm?
Ok made the change.. using profile Samsung TV/D profile. Now it works fine with network but when I attempted mobile it failed. Does the console have to be running?
Post Tue Jul 10, 2012 4:36 pm
Re: stream ogm?
What do you mean mobile? Console doesn't have to be running.
molitar
Post Wed Jul 11, 2012 1:21 am
Re: stream ogm?
I mean when I connect by the WiFi it works fine. But when I attempted to connect by Mobile 3G It would not stream and gave me a transcode lock error.. forgot the exact error number. But I also found another serious problem.. subtitles will not transcode so I am not able to watch the anime anyways.
I will be home tomorrow so I will do some testing with the detailed logging enabled than upload a copy of the detailed log.
molitar
Post Tue Jul 17, 2012 3:57 am
Re: stream ogm?
I think a big part of my problem is Bubble uPNP that I have to use to connect for streaming over 3G or 4G that is causing the issue. I think it's not reliable enough to serve as a third party component to tie the two together. Hopefully beta that I sent and email to I can start testing Serviio with ServiiGo for streaming and eliminate the clunky Bubble uPNP altogether from the equation.
