Can't play MKV on Samsung C8000
rosahas
Post Fri Aug 17, 2012 10:42 pm
Here is the MediaInfo:
Unique ID                                : 183002513844711367786153996638408104257 (0x89AD008BAB0C46E2A5D84B17D0535941)
Complete name                            : C:\Users\Public\Videos\Movies\PTPMovie\PTPMovie.mkv
File size                                : 5.75 GiB
Duration                                 : 1h 16mn
Overall bit rate                         : 10.7 Mbps
Encoded date                             : UTC 2012-08-17 17:47:38
Writing application                      : mkvmerge v5.6.0 ('Kenya Kane') built on May 27 2012 16:44:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format profile                           : High 4:4:4 Predictive@L3.0
Format settings, ReFrames                : 3 frames
Duration                                 : 1h 16mn
Bit rate                                 : 10.1 Mbps
Width                                    : 720 pixels
Height                                   : 400 pixels
Bits/(Pixel*Frame)                       : 1.467
Stream size                              : 5.43 GiB (94%)
Writing library                          : x264 core 125 r2200 999b753
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x111 / me=hex / subme=7 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0
Duration                                 : 1h 16mn
Bit rate                                 : 384 Kbps
Stream size                              : 211 MiB (4%)
Menu
00:00:00.000                             : en:Chapter 01
00:04:08.500                             : en:Chapter 02
00:08:11.000                             : en:Chapter 03
00:15:00.000                             : en:Chapter 04
00:26:18.701                             : en:Chapter 05
00:33:49.001                             : en:Chapter 06
00:39:18.001                             : en:Chapter 07
00:46:01.335                             : en:Chapter 08
00:52:38.502                             : en:Chapter 09
00:58:45.002                             : en:Chapter 10
01:05:17.669                             : en:Chapter 11
01:14:15.336                             : en:Chapter 12
01:16:42.836                             : en:Chapter 13
It works just fine in VLC on the machine.
I have it served up via Serviio. I can see the thumbnail, but when I select it, I get the "Not supported Codec Error". I have selected the Samsung profile as the log shows.
log file
(196.59 KiB) Downloaded 569 times
rosahas
Post Sat Aug 18, 2012 12:54 am
Re: Can't play MKV on Samsung C8000
I downloaded MKVMerge 4.9.1 (from July 2011), just to get an older version .. remuxed my MKV file in this version. Now the Media info is as follows:
Unique ID                                : 174240023709137432739478427382477426689 (0x8315686D43425DE5BFF407D4BC0F1001)
Complete name                            : C:\Users\Public\Videos\Movies\PTPMovie\PTPMovie (1).mkv
Duration                                 : 1h 16mn
Encoded date                             : UTC 2012-08-18 00:38:46
Writing application                      : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library                          : libebml v1.2.1 + libmatroska v1.1.1
Muxing mode                              : Header stripping
Duration                                 : 1h 16mn
Width                                    : 720 pixels
Height                                   : 400 pixels
Duration                                 : 1h 16mn
Bit rate                                 : 384 Kbps
Menu
I am still getting the same error on my Samsung TV as well as my Samsung C6900 BR player. Both have the proper profile as noted in the logs.
Updated log file with Samsung BR player render
(448.03 KiB) Downloaded 573 times
