TV gives device disconnected message
johnnybgoodzm
Post Tue Aug 28, 2012 1:27 pm
running linux 10.10 maverick meercat - latest version of serviio - have installed ffmpeg - pc is connected to router via wired RJ45 cable - router is a thompson 585 - tv is a samsung UE32EH5300 connected by samsungs own wireless dongle. device is set to samsung c/d/e within serviio. - servio see the tv fine - there are no error messages in serviio log file at any time. initially the setup works fine and the servio logo is displayed on the TV in allshare and external devices- plays music mp3's movie avi's great but after approx 2 mins - the tv gives a device disconnected message. The tv has to be turned off and on for it to see the pc again. Interestingly after the disconnection message is given - if you select the movie from recently played - it plays the whole movie faultlessly - any ideas or brainstorms please as I am all out of ideas
Post Sun Sep 09, 2012 11:29 pm
Re: TV gives device disconnected message
it the Linux box strong enough to transcode in real-time?
johnnybgoodzm
Post Wed Sep 19, 2012 5:09 pm
hi petr - thanks for your reply
i dont think that is the problem - because after the disconnected message is gven - if on the tv you select the film from the previously played list on the tv - it will play the movie or song ok for its full play time - this despite the fact that serviio is not shown on the tv ! - but of course you cant browse then - i changed the debug parameter from false to true in the log4j file and watched the log file size - it didnt change when the tv gave the message - however i give the log below
2012-09-19 17:46:19,650 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-19 17:46:19,684 INFO [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-09-19 17:46:19,684 INFO [MediaServer] Petr Nejedly 2009-2012
2012-09-19 17:46:19,684 INFO [MediaServer] http://www.serviio.org
2012-09-19 17:46:19,684 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2012-09-19 17:46:19,684 INFO [MediaServer] OS Linux i386 2.6.35-32-generic
2012-09-19 17:46:19,684 INFO [MediaServer] File encoding: UTF-8
2012-09-19 17:46:19,685 INFO [MediaServer] Headless mode enabled: true
2012-09-19 17:46:19,686 INFO [MediaServer] User home dir: /home/johnny
2012-09-19 17:46:19,686 INFO [MediaServer] Temp dir: /tmp
2012-09-19 17:46:19,686 INFO [MediaServer] ------------------------------------------------------------------------
2012-09-19 17:46:20,769 INFO [WebServer] Socket buffer set to 65535 bytes
2012-09-19 17:46:20,790 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-09-19 17:46:21,026 INFO [ServiioConsole] Starting Serviio Console
2012-09-19 17:46:21,036 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-09-19 17:46:21,037 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-09-19 17:46:21,158 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-09-19 17:46:31,210 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-09-19 17:46:31,518 INFO [MediaServer] ---------------------------------------------------------------------
johnnybgoodzm
Post Sat Oct 13, 2012 7:10 pm
This turned out to be the router timing out somehow - now solved - works real nice now
Post Tue Oct 16, 2012 8:40 pm
cool
castalla
Post Wed Oct 31, 2012 10:44 pm
I have the same issue - device disconnecting - when using the 40D plugin. Seems random - some streams work, then others just disconnect after a random time period. Using xbmc on RaspPi doesn't disconnect. Seems to be an Allshare issue with serviio.
Any hints?
