Serviio stops working after reboot
asnet0007
Post Sat Nov 24, 2012 11:33 am
Hi, If I install serviio pick some video folders to share and select Samsung c/d/e and set to transcode all works straight away. If I reboot my system (server 2008 r2) and try to play a file the tv says the file is not a support type. I have now gone through this process 3 times.
After the reboot I have tried to rescan all shared folders, stop / start the service, change to default and back to Samsung c/d/e and disabled / re enabled transcode.
any ideas?
asnet0007
Post Sat Nov 24, 2012 12:00 pm
Re: Serviio stops working after reboot
Another thing I have noticed is that the film icon thumbs do not get displayed after the reboot.
AndyMc
Post Sun Nov 25, 2012 4:57 pm
Run installer as administrator, right click and select run as administrator.
Might fix it, but is worth a try and can't hurt.
