Samsung Galaxy Tab 2
vinny74
Post Fri Dec 14, 2012 5:41 pm
Hello everyone I just bought the tablet in question and can not get it to go with serviio, the tablet sees the server and the library does not play video files.
I installed the profile for Android but still nothing
P.S. this is an online translation
Post Fri Dec 14, 2012 5:54 pm
Re: Samsung Galaxy Tab 2
Which DLNA client are you using (e.g. BubleUPnP) and which video player app are you using (e.g. MX Player)?
vinny74
Post Fri Dec 14, 2012 6:11 pm
will wrote:Which DLNA client are you using (e.g. BubleUPnP) and which video player app are you using (e.g. MX Player)?
I am using the default client for Android combined with the profile BubleUpnp (in serviio console screen I paired the ip galaxy tab to BubleUpnp - 192.168.1.136 Unrecognized device BubbleUPnP) and video player as the default of the galaxy.
Post Fri Dec 14, 2012 6:20 pm
Install MXPlayer from Google play, the built in player won't work with all formats.
vinny74
Post Fri Dec 14, 2012 6:41 pm
will wrote:Install MXPlayer from Google play, the built in player won't work with all formats.
I installed mxplayer but I can not access serviio I can explain how to do?
laconic
Post Sun Dec 16, 2012 5:47 pm
Try using "UPnPlay" instead of "Allshare" and Mx player as the player. I've just managed to get this combination working with Serviio and a Tab2 7.
Strangely enough, allshare and the builtin video player work with Serviio and my Galaxy S 1 but had to use UPnPlay and MX Player on freind's Galaxy s II and the Tab2.
Good luck.
