Unable to FFWD/REW in Mpeg2 TS Files
keyser
Post Sun Dec 23, 2012 4:06 pm
Hi
I tested your excellent software and must say I like it, but I have one huge issue. I cannot FFWD/REW in my recorded TV shows.
I have tried two different recording suites (Media Portal TV-Server and DVBviewer Recording service) and they both just grab the MPEG4 DVBstream and store it in .ts files.
Using DVBviewer Recording Service as a DNLA server i can FFWD/REW in the recorded files (albeit slowly in the beginning), but using Serviio I'm left with no ffwd/rew functionality.
My playback devices are: Samsung 46C6715 and Samsung C5500 Bluray player using the default renderer profiles. Either shows the same problem and works just fine with DVBviewer Recording Service as a DNLA server. So it must be something serviio is doing (or not doing ;)
Merry christmas to all.
Keyser
keyser
Post Sun Dec 23, 2012 4:13 pm
Re: Unable to FFWD/REW in Mpeg2 TS Files
As a follow up I think Serviio reencodes these .ts files when accessed because I see heavy CPU load early on when watching recorded shows.
I don't think DVBviewer even supports reencoding so it probably just forwards them to the samsung units. Maybe that's the issue?
Keyser
Post Mon Dec 24, 2012 12:13 pm
Can youpst ffmpeg -i for one of these files?
keyser
Post Mon Dec 24, 2012 1:52 pm
That's a strange output....
As far as I can tell it seems to think i MPEG2. As far as I know our Cable signal is MPEG4 and this is recorded directly of a HDhomerum with mediaportal TV-Server.
Does this output make you any wiser?
C:\Program Files\Serviio\lib>ffmpeg -i "d:\TV Programmer\Tror du stadig på julemanden_ - TV 2 - 2012-12-21.ts"
g-config
[mpeg2video @ 0149CAA0] mpeg_decode_postinit() failure
Last message repeated 7 times
[mpegts @ 0149BD40] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 0149BD40] PES packet size mismatch
Last message repeated 1 times
Input #0, mpegts, from 'd:\TV Programm
er\Tror du stadig på julemanden_ - TV 2 - 2012-12-21.ts':
Duration: 27:48:15.79, start: 0.190167, bitrate: 241 kb/s
Program 137
Stream #0:0[0x30]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
, 720x576 [SAR 64:45 DAR 16:9], 4500 kb/s, 26.23 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x40](dan): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo
, s16, 192 kb/s
Stream #0:2[0x68](dan): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Post Tue Dec 25, 2012 11:07 am
Try removing this from the profile
<Matches container="mpegts" aCodec="mp2" />
keyser
Post Tue Dec 25, 2012 11:00 pm
Good call!
That nailed the problem and i can now ffwd/rew in my recordings.
Thanks a lot for your help.
