One Song Then Network Drops Out
crabsoda
Post Sat Dec 01, 2012 5:17 pm
I have a Samsung PN64E8000. I have tried to stream flac files through it. With transcoding turned off, it doesn't work at all. With transcoding turned on it will play one or 2 songs then give me a 'file type not supported message' and drop the network connection. I will then be unable to reconnect to serviio in any fashion without completely turning the tv off and then back on. I was hoping there was some sort of work around. Thanks again for any advice.
ginjaninja
Post Tue Dec 04, 2012 10:05 am
Re: One Song Then Network Drops Out
I think the E is equivalent to my LCD ES.
Try adding flac line to the profile.
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
            <MediaFormatProfile mime-type="audio/x-flac">FLAC</MediaFormatProfile>
        </MediaFormatProfiles>
when you click info on the file it should say media format is 'x-flac'.
crabsoda
Post Sun Dec 09, 2012 5:55 pm
ginjaninja wrote:I think the E is equivalent to my LCD ES.
Thank you so much! That did the trick! You saved me soooo much headache. I seriously owe you a coke. Thanks for helping me out.
atcevik
Post Sun Jan 27, 2013 12:29 am
Did not work for me, added it first to profile 7, then to the main profile, but did not work.
Using samsung E series tv, and after playing first flac file, tv disconnects from serviio.
The file size is being reported as 1:18:00, and seems like the tv thinks the file should go on playing, same with all flac files.
The serviio server reports length smth like 90000000.
Please help :)
ffmpeg result :
c:\Program Files\Serviio\lib>ffmpeg.exe -i abc.flac -y -ar 48000 -ac 2 -vn -f s16be C:\Windows\TE
MP\Serviio\transcoding-temp-16516-7-ORIGINAL.stf
ffmpeg version N-49268-ge9d443c Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 24 2013 23:32:09 with gcc 4.7.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libg
sm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --e
nable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --e
nable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --en
able-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable
-libxavs --enable-libxvid --enable-zlib
libavutil 52. 15.103 / 52. 15.103
libavcodec 54. 90.100 / 54. 90.100
libavformat 54. 61.104 / 54. 61.104
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 33.100 / 3. 33.100
libswscale 2. 2.100 / 2. 2.100
libpostproc 52. 2.100 / 52. 2.100
[flac @ 00000000021e8840] max_analyze_duration 5000000 reached at 5088000 micros
econds
Input #0, flac, from '\\192.168.1.1\hdd_1_1\mp3\Best of BD Jazz\01 - Let me off
uptown.flac':
ALBUM : Best of BD Jazz
ARTIST : Anita O'Day
DESCRIPTION : www.dvdvideosoft.com
ENCODER : Lavf54.29.105
GENRE : Blues
TITLE : Let me off uptown
track : 1
Duration: 00:03:07.55, bitrate: 378 kb/s
Stream #0:0: Audio: flac, 48000 Hz, stereo, s16
atcevik
Post Sun Jan 27, 2013 12:30 am
Oops. Forgot to check notify me with email, thus posting again, sorry for that.
Users browsing this forum: Baidu [Spider] and 29 guests
