Sammy 7000 Series TV - inconsistent playing of HD wtv files
LucianH
Post Tue Jan 15, 2013 8:39 pm
Hi, I'm totally new to Serviio and have just installed it on my Windows 7 64 bit system. I have a Blackgold HD Freeview TV tuner which uses Windows Media Center to record programs. These end up as .wtv files.
I want to play these files on my 7000 series Samsung TV (UE46D7000). So I have configured Serviio (v1.1) with the "Samsung TV / Player (C/D/E-series)" profile and have enabled transcoding with "best video quality" set and "Keep original" Audio channels. I have no problems in playing SD quality wtv files but not all HD files play (one or two do by most don't - file not supported).
Has anybody else seen this and have any suggestions how to fix?
LucianH
Post Wed Jan 23, 2013 9:45 pm
Re: Sammy 7000 Series TV - inconsistent playing of HD wtv fi
I know I'm bumping this post but, without any reply, can anybody advise whether there's a better forum to put this query?
Post Thu Jan 24, 2013 2:39 pm
post detailed log of playing the file
LucianH
Post Sat Jan 26, 2013 8:38 am
zip wrote:post detailed log of playing the file
Thanks for the reply. I've attached the the log entry from the point where I selected an HD program to play on the TV ("E:\Public Videos\Test\Food Unwrapped_Channel 4 HD_2012_10_22_20_28_00.wtv"). This program errors and it skips to the next program which is SD and that plays OK ("Heston's Christmas Feast_More 4_2012_12_23_21_58_00.wtv").
I've not included the whole log, do you need it all? Header info in the log is:
2013-01-26 08:09:08,814 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-01-26 08:09:08,814 INFO [MediaServer] ------------------------------------------------------------------------
2013-01-26 08:09:08,814 INFO [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-26 08:09:08,814 INFO [MediaServer] Petr Nejedly 2009-2012
2013-01-26 08:09:08,814 INFO [MediaServer] http://www.serviio.org
2013-01-26 08:09:08,830 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-01-26 08:09:08,830 INFO [MediaServer] OS Windows 7 amd64 6.1
2013-01-26 08:09:08,830 INFO [MediaServer] File encoding: windows-1252
2013-01-26 08:09:08,830 INFO [MediaServer] Headless mode enabled: true
(25.35 KiB) Downloaded 518 times
Post Thu Jan 31, 2013 8:46 pm
FFmpeg failed transcoding.
Try executing this command and post the output here
ffmpeg.exe -fflags +genpts -threads auto -i "E:\Public Videos\Test\Food Unwrapped_Channel 4 HD_2012_10_22_20_28_00.wtv" -y -copyts -c:v copy -bsf:v h264_mp4toannexb -mpegts_m2ts_mode 1 -c:a copy -map 0:2 -map 0:0 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-7958-7-ORIGINAL.stf
LucianH
Post Sat Feb 02, 2013 10:18 am
Thanks for the reply. I've run the command and output attached.
Serviio ffmpeg cmd.txt
(10 KiB) Downloaded 538 times
Post Sun Feb 03, 2013 6:47 pm
and now try this
ffmpeg.exe -fflags +genpts -threads auto -i "E:\Public Videos\Test\Food Unwrapped_Channel 4 HD_2012_10_22_20_28_00.wtv" -y -copyts -c:v copy -c:a copy -map 0:2 -map 0:0 -sn -f mpegts C:\Windows\TEMP\Serviio\test_wtv.mpg
and if it finishes, try to add and play it in Serviio
LucianH
Post Mon Feb 04, 2013 9:24 pm
Tried that but it produced errors again and output file was empty. Attached is the cmd output.
Serviio ffmpeg cmd 2.txt
(9.13 KiB) Downloaded 504 times
Post Wed Feb 06, 2013 12:13 am
could you try the same command with the latest FFmpeg build from http://ffmpeg.zeranoe.com/builds/
(static 32bit build)
LucianH
Post Thu Feb 07, 2013 8:58 pm
Many thanks - there's been some progress. The ffmpeg cmd you suggested with the latest exe file did run and produced an output file although some errors were reported and the resultant video had no sound. Having copied the latest ffmpeg.exe to the lib folder also meant that I could stream it successfully and it streamed the video OK but there was also no sound.
I added the "-report" option to the cmd line and it produced the following log if that helps.
ffmpeg-20130207-193805.zip
(66.2 KiB) Downloaded 414 times
One other observation. When I play the file on my Samsung TV, I do not get the option to be able to skip of fast forward through the program. I assume that this is a totally different problem - has this been covered on other threads and is there a fix?
Post Thu Feb 07, 2013 10:44 pm
try to add this
<Matches container="wtv" vCodec="h264"/>
just after
<Matches container="3gp" aCodec="amrnb" />
in your c/d/e profile.
Users browsing this forum: Baidu [Spider] and 15 guests
