Samsung BD-C6500 live audio streams
joefish
Post Fri Feb 22, 2013 8:45 pm
I’m a Serviio newbie; Serviio running on Win7 laptop.
If this topic has been solved in the forums I apologize; cause I have looked.
Have Sony BDP-S470 & Samsung BD-C6500 on my network.
No issues with the Sony; it plays the live audio streams just fine.
Trying to get online resources (music / video maybe later) to play on Samsung.
Music & Video local folders seem to play with no issues.
I tried several profile tweaks mentioned in the forums with not much luck.
Samsung sees the steams in the online folder; it just gets stuck on “loading”
And will render not the stream.
Here are some live steams I have tried:
http://lpm.streamguys.tv:80/lpm128-3
http://wqmf-fm.akacast.akamaistream.net ... et/wqmf-fm
http://5163.live.streamtheworld.com:80/WSFRFM_SC
http://174.127.65.10/
At this point, I’m not sure if its firmware or a profile issue.
Thanks for your time. - JF
Samsung BD-C6500
joefish
Post Sun Feb 24, 2013 2:48 pm
Re: Samsung BD-C6500 live audio streams
Update; I was using the latest serviio release 1.0.1
I downloaded serviio-0.6.2-win
Live steams now play on Samsung BD-C6500.
Just for fun I replaced the profile in 1.0.1 with the one in 0.6.2
Still no go on live streams.
Go figure?? - JF
Samsung BD-C6500
Post Tue Feb 26, 2013 6:41 pm
Did you try with 1.1?
joefish
Post Wed Feb 27, 2013 5:09 pm
Mr. Zip- Downloaded v1.1 per your suggestion.
Still having trouble with online audio streams in v1.1; they all check green from serviio console steam check.
Here are the 3 I've tried.
Also, they all play fine in VLC. and play fine in v 0.6.2.
BTW, MP3's in local folders play OK in both 0.6.2 & v1.1.
Now for the weird part, live online video steam (below) will not render in v0.6.2 but plays in v1.1
mmsh://live1.wm.skynews.servecast.net/s ... z_live300k
From serviio status screen (v1.1)
UNKNOWN(yellow dot) / 192.168.1.77 / Samsung WiselinkPro - Blu-ray Player / Samsung TV / player (C/D/E-series)
UNKNOWN(yellow dot) /192.168.1.78 / Sony BD Player - SMP / Sony BD Player - SMP
Both audio & video play on my Sony BDP-S470. Very confusing.
Meant to mention BD-C6500 has latest FW (1027)
Samsung BD-C6500
