A Quick question regarding deleting files from TV,
peter1212
Post Sun Apr 07, 2013 12:27 pm
Hi, I'm about to purchase a samsung smart tv, and never had a smart tv before.
I currently use a "traditional" LCD with a dedicated HTPC (running Windows Media Center 7).
All I want to know please if Serviio (or any other app) allow me to delete files from the PC (I'll have the tv connected using a CAT-5e cable to the pc.
Also, is there an option to resume play of a video file (.mkv for example) where I left it even if the tv was switched off?
Thanks in advance.
Post Sun Apr 07, 2013 11:15 pm
Re: A Quick question regarding deleting files from TV,
You can delete files from the TV. Samsungs will let you resume with Serviio.
peter1212
Post Tue Apr 09, 2013 8:02 pm
Thank you.
