[SOLVED] EH5300 dont play video supported. ubuntu
MarlonMrN
Post Wed Aug 21, 2013 12:36 am
Well, the tittle says my entire problem.
I have a Eh5300, worked perfect with sam allshare in windows. But now that im using linux (i'm a new user*) and using serviio, things isnt that perfect.
I cant play files that are supported on my tv, such as .mkv ... when i try to play it i get a error message telling that the format isnt supported at this time.
ps: i tested the video using a pendrive, worked fine.
Transcoding is disable, what can be happening? U
A big thank you from brazil
ubuntu 13.04
Iveky
Post Wed Aug 21, 2013 12:41 pm
Re: EH5300 dont play video files which are supported. ubuntu
enable it!
MarlonMrN
Post Wed Aug 21, 2013 9:53 pm
why would i enable transcode if my tv can render the file? just to use my cpu and lose quality (1080p dts) - and yeah, worked fine with allshare
Post Thu Aug 22, 2013 1:10 pm
Make sure the Samsung C/D/E profile is selected for your device.
MarlonMrN
Post Sat Aug 24, 2013 10:12 pm
zip wrote:Make sure the Samsung C/D/E profile is selected for your device.
Exactly this. Thank you very much man!!!
Users browsing this forum: No registered users and 50 guests
