Need Help On FOV.MP4 File Not Playing
siriusblack
Post Wed Aug 28, 2013 5:51 pm
HI
Can you please help me out
I Tried playing this file on my Samsung c5900 bdp wont work it comes up Not Support File Format
However it plays on my Samsung ue46c8000 tv
Here is the mediainfo
Complete name                            : C:\Users\mark\Downloads\TV\Midsomer Murders\Midsomer.Murders.15x05.The.Sicilian.Defence.HDTV.x264-FoV.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 581 MiB
Duration                                 : 1h 28mn
Overall bit rate                         : 920 Kbps
Writing application                      : Larry Sanders
Format profile                           : High@L3.1
Format settings, ReFrames                : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1h 28mn
Bit rate                                 : 797 Kbps
Width                                    : 720 pixels
Height                                   : 404 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.110
Stream size                              : 503 MiB (87%)
Writing library                          : x264 core 129 r2230 1cffe9f
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : 40
Duration                                 : 1h 28mn
Bit rate                                 : 114 Kbps
Maximum bit rate                         : 133 Kbps
Delay relative to video                  : 80ms
Stream size                              : 72.3 MiB (12%)
Here is my ffmpeg-i
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\mark>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i " C:\Users\mark\Downl
oV.mp4"
.Defence.HDTV.x264-FoV.mp4: Invalid argument
C:\Users\mark>
Thanks hope this helps
Beta Tester
Post Mon Sep 02, 2013 1:14 am
Re: Need Help On FOV.MP4 File Not Playing
What profiles have you assigned to each device? Have you tried the generic profile?
Is it only this one file? If so, it could simply be something wrong with this file that one device is stricter about than the other.
siriusblack
Post Mon Sep 02, 2013 6:16 am
Thanks DenyAll
I used the Samsung profile for tv (worked)
I used siriusblack profile for my BDP ( did not work)
Have tried the generic profile BDP (not working)
Have tried the Samsung profile for BDP (not working)
It's the only fov.mp4 file I got, So not sure if its just this file
Which wouldn't work or all fov files
Nice 1
Beta Tester
Post Wed Sep 04, 2013 10:21 pm
So use the Samsung C/D/E/F profile - it's designed for both TVs and BDPs
