Can't skip on .wtv files. Logs and Info Attached.
benneh
Post Wed Oct 09, 2013 12:35 am
Loving serviio, so much better than the samsung link POS. Having a problem however with the playback of .wtv files (media centre recorded tv files). They playback fine with transcoding enabled (i'm guessing just a remux happening as their a munged version of MPEG2 I believe, and my CPU barely blips when streaming them), aaanyhow, I can't skip to a time in the file or skip forward/back when watching through serviio on my Samsung UA55ES8000 Series 8.
ffmpeg -i results:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "c:\wtv\Archer_ABC2 - ABC4_2013_10_08
_21_03_22.wtv"
[wtv @ 01B3E7A0] truncated file
    Last message repeated 2 times
[mpeg2video @ 01B3FA20] Invalid frame dimensions 0x0.
    Last message repeated 7 times
Input #0, wtv, from 'c:\wtv\Archer_ABC2 - ABC4_2013_10_08_21_03_22.wtv':
    WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74
    WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000
    Title           : Archer
    WM/SubTitleDescription: Cyril is promoted to field agent, while Malory insti
tutes a strict drug-testing policy. Neither of which sit well with the staff of
ISIS.
    WM/OriginalReleaseTime: 0
    WM/MediaCredits : ;;;
    service_provider: ABC2 / ABC4
    service_name    : ABC2 / ABC4
    WM/MediaNetworkAffiliation: ABC2 / ABC4
    WM/MediaOriginalChannel: 22
    WM/MediaOriginalChannelSubNumber: 0
    WM/MediaOriginalBroadcastDateTime: 0001-01-01T00:00:00Z
    WM/MediaOriginalRunTime: 15855566406
    WM/MediaIsStereo: false
    WM/MediaIsRepeat: false
    WM/MediaIsLive  : false
    WM/MediaIsTape  : false
    WM/MediaIsDelay : false
    WM/MediaIsSubtitled: false
    WM/MediaIsMovie : false
    WM/MediaIsPremiere: false
    WM/MediaIsFinale: false
    WM/MediaIsSAP   : false
    WM/MediaIsSport : false
    WM/Provider     : MediaCenterDefault
    WM/VideoClosedCaptioning: false
    WM/WMRVEncodeTime: 2013-10-08 10:03:26
    WM/WMRVSeriesUID: !GenericSeries!Archer
    WM/WMRVServiceID: !Generated!7302eaa5efae4ce3a7ce80cfbf8dce76
    WM/WMRVProgramID: !Loaders!Glid!Programs!4112:529:530!59032
    WM/WMRVRequestID: 0
    WM/WMRVScheduleItemID: 0
    WM/WMRVQuality  : 0
    WM/WMRVOriginalSoftPrePadding: 438
    WM/WMRVOriginalSoftPostPadding: 300
    WM/WMRVHardPrePadding: -258
    WM/WMRVHardPostPadding: 0
    WM/WMRVATSCContent: false
    WM/WMRVDTVContent: true
    WM/WMRVHDContent: false
    Duration        : 17033818360
    WM/WMRVEndTime  : 2013-10-08 10:31:49
    WM/WMRVBitrate  : 4.749852
    WM/WMRVKeepUntil: -1
    WM/WMRVActualSoftPrePadding: 274
    WM/WMRVActualSoftPostPadding: 300
    WM/WMRVContentProtected: false
    WM/WMRVContentProtectedPercent: 0
    WM/WMRVExpirationSpan: 9223372036854775807
    WM/WMRVInBandRatingSystem: 255
    WM/WMRVInBandRatingLevel: 255
    WM/WMRVInBandRatingAttributes: 0
    WM/WMRVWatched  : false
    WM/MediaThumbWidth: 352
    WM/MediaThumbHeight: 281
    WM/MediaThumbStride: 1056
    WM/MediaThumbRet: 0
    WM/MediaThumbRatingSystem: 9
    WM/MediaThumbRatingLevel: 13
    WM/MediaThumbRatingAttributes: 0
    WM/MediaThumbAspectRatioX: 16
    WM/MediaThumbAspectRatioY: 9
    WM/MediaThumbTimeStamp: 4637570457426437318
  Duration: 00:28:22.08, start: 2.127033, bitrate: 4753 kb/s
    Stream #0:0[0x62](eng): Audio: mp2 (P[0][0][0] / 0x0050), 48000 Hz, stereo,
s16p, 256 kb/s
    Stream #0:1[0x63]: Video: mpeg2video (Main), yuv420p, 720x576 [SAR 64:45 DAR
 16:9], 25 fps, 25 tbr, 10000k tbn, 50 tbc
    Stream #0:2[0x65](eng): Subtitle: dvb_teletext
Debug Log attached.
pc5dczc_clean.log
(27.25 KiB) Downloaded 499 times
Post Fri Oct 11, 2013 3:44 pm
Re: Can't skip on .wtv files. Logs and Info Attached.
If you searched the forum a bit, you'd know that anything above C series will not seek on transcoded content.
