Serviio + sopcast connection hangs on samsung smart tv
jacaque
Post Mon Nov 11, 2013 11:46 am
Hello
I'm very happy for discovered Serviio. Fantastic software and fantastic comunity!
Congratulations!
I've Little problem using Sopcast and Serviio for see live streaming video from my Samsung Smart tv ue46F6400
When I start software (sopcast and after Smart Tv using DLNA, serviio, videos, online .. .etc) It works perfect
But some times connection is losed and I need to re-start play video on my TV again (seleccting videos-online-etc.) It dont shows any error or message. Only stops playing
It seems that in PC connection "freezes" (stops a few seconds) and after it continues well. But I supose that when TV stops of receiving information, it stops playing video
Any idea? is posible to solve it? is posible to increase buffer for dont lose connection? or any othe solution?
Thankyou in advance
Best regards
jacaque
Post Wed Nov 13, 2013 5:39 pm
Re: Serviio + sopcast connection hangs on samsung smart tv
Nobody has any idea ...?
Thankyou
Post Fri Nov 15, 2013 3:20 pm
It might be due to the differences between sopcast protocol and http. Sopcast may allow for missing packets, http does not. So if that happens, the stream may get corrupted and the TV confused.
I don't use Sopcast so cannot comment any further on how well it usually works.
Post Fri Nov 15, 2013 9:23 pm
Try reading the Sopcast posts and plugin that address this problem.
Iveky
Post Fri Nov 15, 2013 10:22 pm
don't waste your time...
samsung tv refuses to continue to play next stream after dropping first stream. so, no help. better to setup sopcast on pc and stream desktop using vlc...
Post Sat Nov 16, 2013 4:50 am
Guess you haven't bothered to read the posts or plugin either. The plugin will restart the current stream on the TV each time it drops the localhost connection.
Iveky
Post Sat Nov 16, 2013 9:58 am
Have you tried it on samsung e/f serie, jhb50?
Post Sat Nov 16, 2013 3:02 pm
No, but you should not need to because on the restart the TV knows nothing about the previous dropped stream, and will see the restart as a new stream from the localhost which we already know works because it played the first time. Obviously however if the Sopcast stream itself has dropped neither the plugin or your manual vlc desktop stream will work.
