Folder browsing on Samsung Galaxy Tab2
sherebiahtishbi
Post Mon Jan 13, 2014 1:41 pm
Hi
I just added folders with my pictures/videos from Serviio Console on my PC. Now when I go to my Samsung Galaxy Tab 2.0 and go to Add Media->Network. I can see my PC is listed as one of the device but when I try to browse all media I dont see all my folders/files I have setup in Serviio Console. Every folder when I drill down it says "No Content found" while I do have thousands of pictures on those folders I added in the Library in serviio console.
Here is how my library looks like in console on PC
Can anybody let me know if I am missing anything here?
Sherebyah
Post Mon Jan 13, 2014 11:14 pm
Re: Folder browsing on Samsung Galaxy Tab2
Three things spring to mind:
  • Check whether you can see the folders/files using Serviio's inbuilt MediaBrowser: http://localhost:23424/mediabrowser/#/browse. The next two points are only worth exploring if MediaBrowser also doesn't see the files.
  • Has your library finished its initial build yet - can take a while particularly if you have 1000's of photos. Check the status in Serviio Console, Library, Shared Folder, Show status - both should be red)
  • Serviio hasn't got the correct access permissions to the Shared folders - see http://www.serviio.org/component/conten ... e?id=21#q5
