After 10-15 minutes the channel is closed
GSMS
Post Fri Jan 17, 2014 3:00 pm
Hi, I have problems with this iptv links and I have a samsung tv F7000 (profile Samsung tv e / f correct series).
The iptv link is properly but after 10-15 minutes the channel is closed.
Only happens with this iptv link rtmp links work correctly.
The use simpletv pc and it works correctly.
I used to Serviio transcoding enabled and also disabled. SERVIIO 1.4
[hls,applehttp @ 0036E920] Estimating duration from bitrate, this may be inaccur
ate
Input #0, hls,applehttp, from 'http://sogecabletok-channel05-apple-live.adaptive
.level3.net/apple/sogecable/channel5tk/01.m3u8?nvb=20140117114607&nva=2014011716
4607&token=04d34cb41ac058937142b':
Duration: 00:00:00.03, start: 24891.096278, bitrate: 52 kb/s
Program 0
variant_bitrate : 0
Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [
SAR 1:1 DAR 16:9], 25 tbr, 90k tbn, 180k tbc
Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 12
7 kb/s
Iveky
Post Sat Jan 18, 2014 12:01 pm
Re: After 10-15 minutes the channel is closed
what is message on tv?
samsung is very sensitive and disconnect too much. use history button on your tv remote to restart playing
GSMS
Post Sat Jan 18, 2014 12:32 pm
Thank you for responding
The tv does not send any message.
The TV channel closes, and returns to the menu of tv channels online.No error message.
Emitting the link from vlc using serviio if it works. (vlc emitting, transcoding off (vlc))
I only want to use the program serviio.
Iveky
Post Sat Jan 18, 2014 2:36 pm
send me link as private message, so i can test what happens on my es6800... i have changed profile
GSMS
Post Sat Jan 18, 2014 4:13 pm
Ok, I've already sent the private message.
