F-5500 file not playing properly with subtitles
hal127
Post Thu Jan 02, 2014 9:34 am
I have the Samsung f-5500 smartTV and whenever I try to play a file with external subtitles I get a message on the TV that "The file might not play properly".
This means that I can't pause, fast forward on control the movie in any way.
Embedded subtitles and files on USB work fine on the TV.
I checked all the checkboxes in the subtitles section.
Any help would be appreciated.
Iveky
Post Thu Jan 02, 2014 1:32 pm
Re: F-5500 file not playing properly with subtitles
check only first option: enable subtiles. other disable
hal127
Post Fri Jan 03, 2014 1:28 pm
I disabled the others and now the file works properly but no subtitle is detected...
neskk
Post Mon Jan 20, 2014 9:50 pm
I have the UE42F5500 smart tv from Samsung too and I couldn't get Serviio to display subtitles too...
Try set up the profile for your device as Samsung TV (E/F-Series) and see if that works. In my case it did.
hal127
Post Sun Jan 26, 2014 6:16 pm
Thank you so much!
Indeed, the profile change helped.
Users browsing this forum: No registered users and 50 guests
