UE46F6600 - Profile Error
TreeID
Post Sun Apr 13, 2014 9:14 am
I am currently testing Serviio, it's a great program ! But i have a question regarding Samsung F6600 Series.
When I select the "Generic DLNA profile" none of the movie covers/thumbnails appears on the tv only the same generic thumbnail but it does when I select the "Profile Samsung TV / Player (E/F Series)" in serviio for my television. That is normal.
But now, when I select "Profile Samsung TV / Player (E/F Series)" i can't play mp4 and some mkv, fastforward is not working, I can't change the audio track of the movie nor select/show subtitles. But it does work with generic profile.
So I have to chose between covers or functionnalities.
Is this a known bug or do I have to fix this issue with a parameter ?
Post Sun Apr 13, 2014 5:14 pm
Re: UE46F6600 - Profile Error
try to turn off transcoding and use the Samsung profile.
TreeID
Post Tue Apr 15, 2014 4:37 pm
Ok i'll try. I update this post if it works.
TreeID
Post Tue Apr 15, 2014 4:50 pm
It works with transcoding off and profile selected ! thanks for your answer ! It's way better now.
Have a good day and thanks again !
