VLC Stream issue
list@furyworks.com
Post Thu May 01, 2014 2:06 am
VLC Stream issue
I am running on the Kubuntu 14.04, VLC 2.1.2, and Serviio 1.4.1.2, I able to view a stream created with VLC using dragon and other media viewers, however I am not with Serviio. When press the "Check stream URL" button I get a red X and do not see the stream listed on the Samsung. I can see music and Photos that I have configured access for, but not the stream. The following is what I get back from a test. What are other things I can do to trouble shoot why Serviio is not seeing the stream?
ffmpeg2theora http://10.11.16.11:8081/desk.ts
Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
[mpeg4 @ 0x95e60a0] hmm, seems the headers are not complete, trying to guess time_increment_bits
[mpeg4 @ 0x95e60a0] my guess is 4 bits ;)
[mpeg4 @ 0x95e60a0] looks like this file was encoded with (divx4/(old)xvid/opendivx) -> forcing low_delay flag
[mpeg4 @ 0x95e60a0] [IMGUTILS @ 0xbfa88ed4] Picture size 0x0 is invalid
[mpeg4 @ 0x95e60a0] get_buffer() failed (-1 1 (nil))
[mpegts @ 0x95de4c0] Non-increasing DTS in stream 0: packet 2 with DTS 0, packet 3 with DTS 0
[mpegts @ 0x95de4c0] Non-increasing DTS in stream 0: packet 3 with DTS 0, packet 4 with DTS 0
[mpegts @ 0x95de4c0] Non-increasing DTS in stream 0: packet 4 with DTS 0, packet 5 with DTS 0
[mpegts @ 0x95de4c0] Non-increasing DTS in stream 0: packet 5 with DTS 0, packet 6 with DTS 0
[mpegts @ 0x95de4c0] max_analyze_duration reached
[mpegts @ 0x95de4c0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://10.11.16.11:8081/desk.ts':
Duration: N/A, start: 48007.477378, bitrate: N/A
Program 1
Stream #0.0[0x48](): Video: mpeg4 (Simple Profile), yuv420p, 1600x1200 [PAR 1:1 DAR 4:3], 0k fps, 90k tbn, 9 tbc
Unable to open output file `http://10.11.16.11:8081/desk.ogv'.
Thank you for any advice you may be able to provide.
Post Thu May 08, 2014 12:38 pm
Re: VLC Stream issue
can you post again the result of
ffmpeg -i http://10.11.16.11:8081/desk.ts
