Issues with menu lagging on UN46ES6100F
• Page 1 of 1
Looked around for an answer but I couldn't find it on the forum. Basically, I run Serviio from my PC and my Samsung is wired to my router. I press the MENU button on the samsung remote and choose Serviio. When the folders come up things start to lag real bad. If I try to move to a different folder or icon, I have to press the button several times for it to move. When I finally get to the file I want I can choose it and things work just fine. I can play anything without stutter or lag. Any thoughts about the lagging menu? Help would be appreciated.
Re: Issues with menu lagging on UN46ES6100F
never had such behaviour. i have 46es6800, and would try factory reset...
widgets work ok?
widgets work ok?
Yeah widgets work ok. It just happens when I am browsing the files when I have selected Serviio. It's really strange.
try clean servio instalation with only few folders/files, just to check speed in that case...
I'll give that a shot, thank for your help!
FWIW for anyone else having this issue, I figured out what was causing the problem. It was the latest version of Serviio. I reverted back to the version previous to this one and everything is going smoothly in the menu screen. I can move from icon to icon using the samsung remote without having to press the arrow button a bunch of times. Hope this helps anyone else with this issue.
yes i too have the issue. ever since i formatted my computer and put the new serviio version on, it works the first time, where i click on the serviio icon on the tv (the yellow square with the black circle arrows appear), and everything runs great. But if i log off and log on again to the logo changes to a question mark. Still can log on but scrolling through folders is a pain, but once you click onto a video, all works normal. the unfortunate trick is to make it work again i have to reboot the computer and it will only work once again properly.
i have 2 series 6 Samsung TV 50 Inch and 1 Series 8 60inch, all hard wired.
im downloading an older version as im writing this and i get back to you if it woks for me
i randomly installed version 1.4 and it totally worked. everything is back to normal. good one
• Page 1 of 1
