Serviio not showing on TV until server restart
AaronK
Post Sat May 10, 2014 12:59 pm
Since upgrading to 1.4.1.2 from 1.4, each time I turn on the Samsung TV I need to stop and re-start the server on the PC for it to show up in the source section on the TV. Once I restart it, it's fine, but will have to repeat the process every time I turn on the TV.
This was not the case with 1.4. It would always show up in the source section on the TV after a few seconds of turning on the TV. Considering downgrading again if it's not solved.
Any ideas?
Post Tue May 13, 2014 6:28 pm
Re: Serviio not showing on TV until server restart
There should not really be any change related to this between the 2 versions.
fonzeeee
Post Mon May 19, 2014 4:32 pm
Just upgraded today, also having same issue. Also using Samsung TV. Never had this happen once on 1.4 version.
After watching 1 file it loses connection everytime, to get it to sync up again I have to pull out network cable from tv then reset serviio turn tv off and on then wait 4mins for it to pick it up everytime a file finishes playing.
Doing either one sololy (resetting serviio or replugging the network cable) seems to not help at all, spent about 15mins trying both sololy....
Cant find any 1.4 download links :(
Can someone please show me where I can downgrade?
Edit : The problem resolved its self today, have no clue what happened or why :( sorry to post the other day was very annoying to troubleshoot. Glad its working now and thank you for serviio.
woodpusherghd
Post Sat May 31, 2014 3:28 pm
I have the same problem, I have to stop and re-start the serviio server before it's detected by the TV. I didn't have this problem on the earlier version. I'm running serviio on Ubuntu server 12.04.
