Post Sun Jul 06, 2014 4:38 pm
Disconnect when accessing some folders
I'm experiencing an annoying error, though I can't say if it is caused by my TV (Samsung UE32ES6200 (orig. Fimrware)) or serviio (Win7 x64 Java 8u5(also had the problem with Java 7)).
When it comes a certain amount of subfolders and some movie files (i.e. 95 subfolders and 5 movie files or 7 subfolders and one movie file (all movies are in *.mkv containers but compatible with the tv)) the DLNA client on my tv throws a "Disconnect" warning and serviio vanishes for half a minute to a minute from the source choices of the tv. After that I can rechoose serviio and the complete folder is loaded in 2nd try.
I checked the serviio logs but they don't contain any errors that a divice had a dc.
My guess would be to little RAM in the tv.
Hope someone can give me some input.
Thanks in advance and best regards
IG
EDIT:
just realized the derby.log it says "Unknown error" (file attatched foldernames above Serviio removed)
derby.zip
(1.59 KiB) Downloaded 466 times
